afr ls1 vs l92 ls2
Old Nov 25, 2007 | 08:39 PM
99reddevilFRC's Avatar
Default afr ls1 vs l92 ls2
in your opinion, which would make the most power? a ls1 w/afr 205s 90/90 w 224 cam or ls2 w/l92 heads w/l76 w 224cam? both with same comp. ratio.
Old Nov 25, 2007 | 10:45 PM
sroach20's Avatar
with the ls2 you would get more cubes and you could stick a larger cam in there. the more cubes you get the larger the cam you can use, a 230 in an ls2 would idle the same as a 224 in an ls1.
Old Nov 26, 2007 | 05:59 AM
HSV-GTS-300's Avatar
Here's an example for the LS2.
LS2 with unported unmilled L92 heads,L76 intake, comp ratio = 10.4
224/230 .581/.591 114 LSA
452rwhp and 415rwtq
Old Nov 26, 2007 | 11:42 AM
Blindmelon's Avatar
Was the PV clearance ok with the cam & heads (L92) I milled mine .025 to get a little more compression. L92/LS3 heads are the way to go.
Old Nov 26, 2007 | 12:23 PM
fenix999's Avatar
i say LS2 L92 just because there's more cubes and just as good if not better head/intake #'s (well L76 sucks but you get the idea)
Old Nov 26, 2007 | 01:17 PM
c5_ls1_6spd's Avatar
L92 are pretty huge for the 364ci. So Ima have to go with AFRs w/ the FAST 90.
Old Nov 26, 2007 | 10:36 PM
mike c.'s Avatar
I made great power with the AFR heads and LG Motorsport x3 cam 463hp 414tq on a mustang dyno. My l92 set up,we tried to dyno it,but my clutch would not hold. I still got close to 490hp 430tq on the same dyno. With the clutch holding I will see around 515-520hp 450-460tq. Also the L76 Intake everyone says sucks and falls on its *** at 6,100 rpm's. Mine pulled to 6,500rpm's and held strong all the way to 7,000.I don't think the intake sucks that bad,(i'm sure f.a.s.t can make a better one) I just think some people have no idea how to choose the proper cam to match.
Old Dec 26, 2007 | 10:58 PM
DoesSpeedTurnUon's Avatar
Did you make that with the X3 cam and L92 heads, the 490ish?
Old Dec 27, 2007 | 10:31 AM
black_z's Avatar
Some more details on your setup would be nice! Cam specs? Is the intake ported? How many cubes?
Old Dec 27, 2007 | 11:08 AM
SS Enforcer's Avatar
I have a 6.0l here in Australia with ported L92's on it and they work very well. I havn't been able to dyno mine yet as the dyno got water damaged and it won't be running for another week but computer logging under load showed a progressive rise in Cyl/Air all the way to 6500/6600. It didn't seem to be falling over at all. We are expecting 450hp+ with the A6 on a mainlog dyno add some more to convert to dynojet figures.
The 224 cam seems plenty big enough for the 6.0l as the intake valves are a lot bigger than ls1 valves and should flow better than a 224 on a ls1.
cheers
Old Dec 28, 2007 | 01:37 AM
njc.corp's Avatar
Question
cheers
u dont feel that the l92 heads even though its on a six litre needs a bigger cam then a 224?
Old Dec 28, 2007 | 06:56 PM
The highest HP for a 6.0L I have been able to find is with a 224 228 camshaft with cnc'd stage 2 heads. This made around 490 I believe. Lobe is a secret but I think it was an xfi on the intake.
If the intake valve is a lot bigger than a ls2 then surely a 224 on a L92 will flow more than a 224 on a ls2 ?
My car is still nicely driveable with the stock convertor at 750 rpm idle hopefully we can get that down to 620 with some more fine tuning.
I have seen some Big cammed cars that sound great are bastards to drive and don't go compared to well setup smaller cams.
cheers
By Brett Foote | 2026-06-04 05:00:17
