Suggestions for winter storage, sort of...
Old Dec 2, 2007 | 01:19 PM
ArKay99's Avatar
Default Suggestions for winter storage, sort of...
I have a brand new LPE 403 block mounted in my car right now. I'm waiting for heads to arrive. However, they won't until January sometime. In New Jersey the roads are usually a mess by then and we have 2" of snow on the ground right now. I will probably keep the car in the garage and covered unitl spring, because even if I get it fired up I'm going to have to break it in, and that means driving it around in the snow and crap, which I don't want to do.
What I am thinking is to 'seal' up the motor until I get ready to start it in the spring. I have a set of 241 heads I bought for a stock build and strips of the plastic bag the motor was shipped in over the cylinders. I also pressure primed the oil system with a pre-luber so there is a full pan of oil inside and throughout the galleries. I was thinking of placing the 241's on the cylinder with the plastic between (I have ARP studs mounted), and putting the water pump on to 'seal' the motor. I don't have gaskets, but I could get them. If I do this, should I wipe the cylinders with some oil to keep them from rusting? If not, what would you suggest?
Old Dec 3, 2007 | 03:07 AM
Blktie8's Avatar
Default engine
Roger
If it has oil all over everything .I would just keep dust out cover it with towels
you're only talking a month now .
I wouldn't put plastic between the engine and heads holds moisture in and might stick
Just my .02
John
Old Dec 3, 2007 | 09:31 AM
bczee's Avatar
As long as you keep everything dry and dust free.. I would not worry about it.. many cars and other projects have sat around a lot longer that what your plan is for storage.
I had my engine sitting in my sted outside over the winter with just a large plastic bag over the engine and stand. I just stuffed rags in the open ports and taped they shut.
Old Dec 3, 2007 | 07:46 PM
ArKay99's Avatar
Hey John, it's been a while. Thanks for the advice. If I had my choice I'd have the new shortblock in the house next to me on the couch, lol. I guess I'm a little **** after all the money I dumped into it. How's your ride these days?
Thanks for the advice bczee. You're driving my fantasy muscle car.
