LS7 Piston Options
Old Dec 12, 2007 | 02:16 AM
scott_mckinney's Avatar
Default LS7 Piston Options
Hi. Does anyone have any experience with aftermarket pistons for the LS7? Looking to lower compression and run a large amount of boost on the engine. Any information or piston suggestions? Please advise.
Old Dec 12, 2007 | 04:35 AM
njc.corp's Avatar
je-diamonds-mahle-just to name a few-
je pistions website should have some details on dome's and ring's +size etc etc
Old Dec 12, 2007 | 06:45 AM
toneloc60's Avatar
I'm having Wiseco make mine. http://www.wiseco.com/PDFs/Catalogs/AB08/Chevrolet.pdf
They're top notch. They forge and machine their pistons in house, keeping costs low while offering a lot more. That's why I have them making the pistons for my build.
Old Dec 12, 2007 | 08:51 AM
Katech_Jason's Avatar
LS1TECH Sponsor
We have a 9:1 LS7 piston that we recently put through some brutal testing. It performed very well. They are $159/ea
Old Dec 13, 2007 | 12:54 PM
Hi Jason. Shoot me an email with piston information ASAP...
Old Jan 4, 2008 | 02:12 PM
Any info? I got no emails and no additional information...
Old Jan 4, 2008 | 03:02 PM
427's Avatar
427
Both Wiseco and Diamond have pistons with the LS7 compatible valve notch for around 650-750 a set. They both make a nice piston that will handle serious power as shelf parts depending on your power adder. If you want to call we can talk about your needs in detail and help get you the right parts.
Kurt
Old Jan 4, 2008 | 04:02 PM
Shawn @ VA Speed's Avatar
We have some custom JE's we use for our LS7 turbo motors,9-1 comp.
Made over 1000hp on pump gas,and over 1500 on race gas.
$125.00 each.
Old Jan 4, 2008 | 08:49 PM
Tom@SpeedInc's Avatar
All the big companies machine their pistons in house, now I think your referring to Wiseco has their own foundry?
The rest of the 2618 forging world go though one of the few foundries in its existance, its a unique high grade aircraft aluminum ( or aluminium depending where you come from all the companies use their own proprietary dies.
Old Jan 4, 2008 | 10:16 PM
racer7088's Avatar
Thumbs up
Fraser,
Wiseco does have there own forging facilities including many different types of forges depending on what base forging and material they are doing. The other American piston companies do not have the same capability to do all new forgings if they wanted the way Wiseco can and does (besides Mahle).
That's how they have dominated some of the racing they have been in when they came in full force as they didn't need the fully machined billet stuff the others had to run and they could keep changing their forgings and have a stronger, lighter and more stress free piston. When you break that forging skin on the bottom of a piston it will be much more likely to crack. You won't usually see formula car pistons made any other way.
Also some of the pistons that are talked about on LS1tech are not machined in house. At least two are forged also machined at Wiseco believe it or not including all Lunatis newer (and better) stuff.
Old Jan 5, 2008 | 09:06 AM
WE TODD DID's Avatar
You can get a set of venolia's for around $500 a set, plus pins.
