Cam experts inside,L92 related..
Wizeass: I'm suprised the single plane didn't show a significant difference in the overall power curve. Irrespective of the net numbers I would expect a difference in the shape of the curve between a plastic intake and a single plane. (Although I'm not sure if you did a back to back comparison).
Other than dialing in for peak power output, getting the AFR right is mainly important when in the car. As is the case with carbs which usually require some adjustment from dyno to car. The fueling sensitivity is mostly related to the relative load on the crank at any given instant.
Some engine mangement systems will fuel and time each cylinder in pretty short order but they cost some big $'s.
Richard
Richard
Gotcha!
When do you expect to get the new cam installed and running?
Richard
D.J.
For example a local Dynojet rated our buddies 427 at 524rwhp, Rick's dynoed it close to 560rwhp. Big discrepency there...
the problem i have with that is this... the before dyno looked about right, and it showed a big increease from the before to after.
seems that his results are real to me.
If you like what he is selling then buy it, but don't say that I didn't warn you that it is just the same as everyone else is selling. My comparison between dynos was to show that he hasn't exactly nailed it, it just looks bigger on his Dynapak.
That is what is up with that.
My point was just that the numbers arent really the iussue, what i would look at is the difference in the before and after numbers.
Actually despite my personal problems with Rick, I just think it is the nature of the type of dyno he is using. Rick will tell you he has it calibrated to read like a Dynojet, but there are quite a few of us that have done literal back to back dyno sessions to show his results are typically higher. I don't think he is actually trying to con anyone (at least I hope not); but that is just the nature of the Dynapack... Sort of like the difference between a Dynojet and a Mustang dyno...
Regardless the gains would be better measured baseline to end result, but even then it seems the Dynapack registers a larger variance the higher the HP goes. Most dynos there is a ~5rwhp variance that is considered normal, I just think it gets higher on the DP the higher the rwhp goes. IE the end results will seem larger as the variance has gotten larger... *shrug*
Sorry for the misunderstanding.
It really is a shame that things like this happen.. i.e. some people inflatting numbers or being dishonest, because it F's things up for everyne else.
I mean, Rick may be on to a top notch combo and got the tune down, but is getting doubted due to shady people in the past putting doubt in peoples minds.
I dont know Rick, ron, mike, etc. I havent dealt with any shops, Vengeance or others. So i cant and wont speak on anyones behalf or poop on anyones results. But it sucks that this happens, cause it makes it really hard for people like me (who dont have much experience or knowledge in this game) to know where to go to get work done or who to trust.
How do u know who has got your best intereest and performance at heart, or who is just trying to sell you something?? (Rhetorical question)
