Help me with this question please
Old Dec 29, 2007 | 11:36 AM
mohammed_k81's Avatar
Question Help me with this question please
With a proper tune this should not be a problem with 98 octanes?
cranck shaft callies 4.000
rods H-PEM eagle 6.125
piston je pore 4.000 cerameck coated dome volume +10 custom
gaskets cometic pore 4.160 thickness 61
heads afr 225 cc flow 350 2.080 1.060
oil pumps slp
pore 4.125
strock 4.000
cylinder 8
piston volume + 10 dome
heads 72
gaskets th. 0.0 61
= cui. 428
= liters 7.01
= Compression 12.59
Old Dec 29, 2007 | 12:27 PM
WizeAss's Avatar
Originally Posted by mohammed_k81
With a proper tune this should not be a problem with 93 octanes?
oil pumps slp
pore 4.125
strock 4.000
cylinder 8
heads 72
gaskets th. 0.0 61
= cui. 428
= liters 7.01
= Compression 12.59
Your compression and timing is what effects the amount of Octane you can safely run... as well as intake temps, quality of gas, and cam overlap.
With that kind of cranking compression you are on the edge.
I have a street car that is around 11.25:1... and in Texas heat if I where to mill that down to 11.8:1 I would start to worry about needing higher octane.
Also.... I thought in Kuwait 95 octane was the lowest you could purchase?
Old Dec 30, 2007 | 02:15 AM
Smile
Sorry yes the lowest is 95 my mistake i ment run it on a 98 octane
