head and intake is all i need to choose
edit....i found it http://www.mrnitrous.com/LS-SPYDER%20MANIFOLD.htm
I don't think it matters what kind of intake you use for boost, no loss of low/mid or anything sinced the air gets jammed through no matter what rpm your at. And a sheet metal is stronger for making alot of boost and power up over 1,000 rwhp. Plastic intakes have broken/cracked under alot of boost.
Thats how i undrrastand it.
So with the Borg Warner S80 on a 370ci iron block, AFR heads and an LS6 intake...what compression would you go with for a daily driver/street car?
and what rwhp do you think it would make at a reliable amount of boost? What psi woudl that be?
Figure sue with the OFI single kit, that thing looks nice!!!!!
This is what I'm 95% sure i'm gonna do instead of N/A + spray.
Everything you mentioned in that list of parts is the easy part. Its the piping for the turbo kit that I don't know where to turn. Buying the OFI kit I guess would be best but I think that'll blow right past my $14K budget.
