Take your dyno guesses now!!
Old Mar 22, 2008 | 12:43 AM
  #41
Pwebbz28's Avatar
Yeah engine dyno. Nitrous numbers are mine for now. We are almost certain there is another 30-40hp in the setup once the valvetrain is set up properly.
Old Mar 22, 2008 | 01:04 AM
  #42
LC's Avatar
LC
well those numbers sound sweet.. how much nitrous is being sprayed?
what pistons did you used?
Old Mar 22, 2008 | 01:29 AM
  #43
Pwebbz28's Avatar
I bought coated diamonds. Wiseco i think it is now makes a l92 piston. 4.070 is the size i believe.
Old Mar 22, 2008 | 01:42 AM
  #44
TT632's Avatar
Those are some big flow numbers. My 18/15 deg conventional sbc heads flow your same 0.700 lift numbers, 377 cfm (superflow 1020 #s). With a similar lift (with more duration and a solid roller cam) on a 15:1 421 it hit 608 rwhp NA with a glide on gas. I don't know how you could be below 550 at the wheels with a more aggressive solid roller. When you have that kind of potential I don't know why you would leave so much on the table by using pump gas.
Old Mar 22, 2008 | 01:45 AM
  #45
needadvice's Avatar
Originally Posted by Pwebbz28
Intake Exhaust (without pipe)
.200 162 126
.300 240 180
.400 302 218
.450 316 225
.500 340 236
.550 353 243
.600 361 250
.650 369 254
.700 377 257
.750 382 263
.800 388 268
.850 395
.900 399
.950 405
1.00 414
Those are the numbers on the heads. I was wrong the first time. The cool thing is, these heads never backup. Its a great port really!
That makes more sense
Old Mar 22, 2008 | 02:03 AM
  #46
Pwebbz28's Avatar
Want this car to run on 93. This is a hydraulic roller cam. The car is a full weight 01 ram air with ac and everything 6speed car. this thing will see 600 at the wheels on motor.
Old Mar 22, 2008 | 12:32 PM
  #47
WizeAss's Avatar
One of the big name porters on here was one of his teachers. .
who is that?
Old Mar 22, 2008 | 12:34 PM
  #48
WizeAss's Avatar
.200 162 126
.300 240 180
.400 302 218
.450 316 225
.500 340 236
.550 353 243
.600 361 250
.650 369 254
.700 377 257
.750 382 263
.800 388 268
.850 395
.900 399
.950 405
1.00 414
That is funny...... as much as he is the greatest porter out of SAM..... Greg Good spent a few hours on my heads and came up with similiar numbers on a very reliable bench. FWIW.
what bore where they flowed on again? Seems interesting that you are not seeing the lose in flow at the lower lifts or a smaller increase due to shrouding of the valve.... not a porter in the world can equate for a larger valve small port problem the L92's seem to have. Dang valve is too close to the chamber wall.
Old Mar 22, 2008 | 10:39 PM
  #49
Pwebbz28's Avatar
Perhaps MY head porter is just THAT good! Just because they are a little better/different than you heads doesn't mean its bullshit. This motor has been in the works for over a year. Alot has been learned in this build. Like I said Boone else has ever done this.
Old Mar 24, 2008 | 09:11 AM
  #50
GrannySShifting's Avatar
Don't let the cam specs fool you. Its not an off the shelf lobe by any means. The closing speed of the intake valve is nuts
We have had rocker issues and valve float at 7300. Before then it is making 710HP 580TQ
How exactly did you EXPECT that to work out?
Should have no problem making 750 with that much cyl head right, Id think even more. I think we are making around 650-690 at flywheel Id guess, using 290-310 cfm max, with 42x inches. It peaks at 7400, so Im not sure about all the talk about crank limiting whatever. More stroke in any given engine makes more power. Cylinder heads and camshafts dont move air, pistons move air, they just open the right door. At the right time hopefully. And dont slam the door on the way in the house! They dont like that either.
Old Mar 24, 2008 | 01:33 PM
  #51
Pwebbz28's Avatar
I should have said opening speed. The IVC side is more like XFI stuff I think we will pick up close to 30 with good rockers.
Old Mar 24, 2008 | 02:44 PM
  #52
LC's Avatar
LC
which rockers were you using.. stock ones?
Old Mar 24, 2008 | 02:59 PM
  #53
Stang's Bane's Avatar
Tell Mike Keith said Hi...
Old Mar 24, 2008 | 03:18 PM
  #54
cast iron's Avatar
DNF
Old Mar 28, 2008 | 10:36 PM
  #55
bad2dbone's Avatar
I Say 585
