L92 CNC Vs. Standard L92
Old Oct 20, 2008 | 10:28 AM
Stang's Bane's Avatar
Sorry for the misinformation. I was told by a friend that called about them that they were in fact the PRC ones. Once again, sorry about the misinformation.
Who designed the port for the GMPP ones??
Old Oct 20, 2008 | 10:31 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That I do not know.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 20, 2008 | 03:27 PM
Hans Grüber's Avatar
Originally Posted by Matt@Texas-Speed
We've flow tested those heads as well as the prc l92 heads next to each other. Both sell for about 1000-1100 for the pair fully cnc ported. Our PRC L92 heads gained 25rwhp over a stock l92 head on our dyno test engine! Pay a couple hundred extra bucks & get the prc cnc ported heads, you'll get better p/v, better air flow, & better power than the stock l92 head!
What are you thinking about installing this thing on?
So how do the PRC heads compare to the GMPP CNC heads?
Old Oct 22, 2008 | 08:51 AM
dannyual777's Avatar
From: Montgomery (Lake Conroe,) TX north of Houston
Anyone ?
Old Oct 22, 2008 | 09:16 AM
Sorry guys, I have a flow chart here somewhere comparing the two, as well as a back to back dyno comparison. I'll try to find them and get them up here ASAP.
__________________
Old Oct 26, 2008 | 06:16 AM
Any update?
Old Oct 29, 2008 | 06:51 AM
Matt, were you able to find the information?
Old Oct 29, 2008 | 03:44 PM
Sorry for the delay! The first one is a chassis dyno comparison for a 418 swapping from stock LS3 heads to the PRC heads. The second is a back-to-back flow comparison from the GMPP CNC'd LS3 head to the PRC LS3 head.
__________________
Old Oct 29, 2008 | 04:40 PM
Clevite Kid's Avatar
Nice increase in flow in the middle - that will help a lot in getting the cylinder filled.
Old Oct 30, 2008 | 06:40 PM
Is anyone else not able to view the pics
Old Oct 31, 2008 | 09:12 AM
http://precisionracecomponents.com/prcl921.jpg
http://precisionracecomponents.com/prcl922.jpg
Maybe that helps?
__________________
Old Nov 9, 2008 | 10:44 PM
  #32
IntegraVTEC's Avatar
So if I read this right the GMPP CNC heads flow better than the PRC's right?
Old Nov 10, 2008 | 09:24 AM
  #33
Negative. The top line is the PRC head, lower is GMPP.
__________________
Old Nov 10, 2008 | 03:32 PM
  #34
thanks for clearing that up for me. I'm looking for some heads and the can't decide between a good cathedral ported head or the l92/ls3 style.
Old Nov 10, 2008 | 06:52 PM
  #35
vjjack04's Avatar
What cam did you use with this combination? (did I miss this?)
