Spec me a sleeper cam!
Going from XE lobes to XFI lobes would gain you around 5 rwhp. While this is basically free hp (same drivability), you will need to run more expensive dual valve springs and you will have a noticable increase in valve clatter. Not my idea of stealth (if you're wanting to be sneaky).
Also, the LS6 lifters in the CTS-Vs are not any quieter than other factory LS1 lifters.
Custom cam using XFI lobes?
