ls3 blocks are they stronger? anything else diff on them? are better?
Old May 17, 2008 | 03:59 PM
blu00rdstr's Avatar
I'm near done with a forged LS3 for boost setup. The shortblock and parts came from Bruce @ PowrMax, great price, professional work.
Diamond L92 pistons, Compstar crank and rods, 4.060" x 3.622" (376ci), LS3 block, LS3 heads, Stainless intake valves, Comp 921 springs, LS7 lifters, Synergy custom cam, L76 manifold, customized LS2 fuel rail, 75lb injectors.
Old May 17, 2008 | 04:47 PM
Bill00Formula's Avatar
KCS - I had e-mailed Fraiser at Speed, Inc. a while back and he had mentioned that there was some sort of problem that shows up on a lot of the LS3s where the LS2 seemed to be consistently better. I don't recall the specifics or if he even went into it but basically said the same thing as you. I was suprised to hear this since I would think they would have to meet the same quality standards. If anything I would have thought the LS3 would be better.
I just wondered if these improvements would correct that problem. It would be better to have a slightly bigger bore and CIs.
Old May 17, 2008 | 04:49 PM
Nice engine!
Old May 17, 2008 | 08:55 PM
SmaknaSS's Avatar
Originally Posted by KCS
From what I've seen, the aluminum 6.2L blocks suffer from a sort of "core shift". Like the aluminum is cast around the sleeves, and then bored offset leaving one side of the sleeves thinner (as in .070" thick) and the other thicker. Our shop rejects blocks all the time for such problems.
The LS2 blocks seem spot on 99% of the time. I personally feel the LS2 is the better of the two.
I hear is problem with "Core shift" was aproblem with the older LS3 Blocks. Is this not true?
Old May 18, 2008 | 11:44 AM
KCS's Avatar
KCS
Moderator
I agree, I would want the bigger bore but not at the cost of reliability. I'm not saying the aluminum 6.2L blocks are gonna blow up or anything, but it's just not something I would gamble on. Especially on a FI application.
Old May 18, 2008 | 11:45 AM
KCS's Avatar
KCS
Moderator
I don't know about older blocks. We just sent back two brand new blocks last week.
Old May 18, 2008 | 11:47 AM
KCS's Avatar
KCS
Moderator
Looks like a nice build. Whats the specs on that piston, if you don't mind me asking? Compression height, ring pack, etc?
Old May 18, 2008 | 12:22 PM
1.8t's Avatar
Is GM using these LS3 block w/ off center bore in their corvettes? Meaning would these blocks pass through QC on their end and be used anyways?
Old May 18, 2008 | 12:38 PM
blu00rdstr's Avatar
Here are the specs I know, the builder knows a few more details.
Old May 18, 2008 | 01:21 PM
KCS's Avatar
KCS
Moderator
Perfect, thank you sir.
