ls3 blocks are they stronger? anything else diff on them? are better?
Old Feb 4, 2008 | 01:36 PM
BigRich954RR's Avatar
Default ls3 blocks are they stronger? anything else diff on them? are better?
are the the ls3 blocks better then ls2. looking to start building my new motor.
Old Feb 4, 2008 | 01:59 PM
Cheatin' Chad's Avatar
They have a larger bore. They should be less durable in a FI application, at high HP levels as a result of this.
Old Feb 4, 2008 | 02:20 PM
Evilways's Avatar
Actually, they're set up for FI, as the LS3 is the basis for the LS9 in the supercharged ZR1. LS3+GM supercharger=LS9.
Old Feb 4, 2008 | 06:14 PM
05 GSXR 1XXX's Avatar
i would say the ls2 F/I would be stronger, than the ls3 F/I but not a big enough difference....
im sure the ls3 will run you a lot more money so just get a ls2 and save your money!
Old Feb 4, 2008 | 06:26 PM
slt200mph's Avatar
The ZR1 block is a different block than the LS3..
Old Feb 4, 2008 | 08:21 PM
Shawn @ VA Speed's Avatar
the ls9 block is different,but anyway the ls3 block is in no way weaker than the ls2,sleeves are the same thinkness and they are about the same price new,go with the ls3,bigger bore is always better
Old Feb 5, 2008 | 05:06 PM
Randy WS6's Avatar
how big can you bore a LS3 block? ,factory bore a 4.065" right ?
Old Feb 6, 2008 | 08:43 AM
slt200mph's Avatar
If my memory serves I beleive that I read in the GMPP catalog that they could be bored 30 thousanths. Not going to pick up much displacement with that ... I would save that in case you had to clean up the bores on a rebuild down the road.
Old Feb 9, 2008 | 07:09 PM
I should have elaboated further it seems. it WILL be weaker at extreme power levels due to reduced material between the cylinders. Less material equals less strength everytime when all other factors remain constant. This will not have much affect a mid level power biuild (600hp or so)
Old Feb 10, 2008 | 03:52 PM
Big Bird WS6's Avatar
from my local dealer. i can get a ls3 cheaper then a ls2 it is about 200 dollars cheaper
Old Feb 10, 2008 | 03:57 PM
shawn, can you get me the gm part number or both the ls3 and ls9. cause i think they are the same block. just different internals
Old Feb 10, 2008 | 09:51 PM
Bill00Formula's Avatar
Kind of odd that you can get an l92/ls3 block cheaper since the L92 block lists for 1,821 versus 1,393 for the ls2. Online I saw the ls2 as low as 999 versus 1350 for the ls3.
Old Feb 11, 2008 | 12:29 AM
Dom's Avatar
Dom
Those are prices for just the blocks. Who here makes complete engines based on LS2/LS3 blocks?
Old Feb 11, 2008 | 08:19 AM
Just about very site sponsor that builds GenIII based engines. Look tot he right
Old Feb 11, 2008 | 02:12 PM
BAD2000TA's Avatar
Really?!? How much can you get the LS3 block for? I might have you pick you up for me.
Old Feb 11, 2008 | 05:17 PM
slt200mph's Avatar
They are the same displacement with the same bore and stroke (376 cu. in.) but not the same block.
Old Feb 11, 2008 | 11:06 PM
Dom's Avatar
Dom
That SC from the LSA or LS9 should bolt up right?
Old Feb 12, 2008 | 02:33 PM
pm me your phone number
Old May 17, 2008 | 02:07 PM
Don't know if anyone saw this(from corvette blogger.com). I was thinking about using this block in a forced induction application. Seems like pretty good news and a good alternative to the LS7 block assuming you choose not to go with the LS7 heads.
Corvette's Chief Engineer Tadge Juechter Hosts A ZR1 Chat
CDINGERS:
What changes to the ZR1 LS3 block will carry over to the production LS3? Oil Squirters, 11mm head bolts, etc.
Tadge Juechter:
The block structural improvements and the improvement in bay to bay breathing will be included in LS3 blocks for 2009.
Old May 17, 2008 | 03:40 PM
KCS's Avatar
KCS
Moderator
From what I've seen, the aluminum 6.2L blocks suffer from a sort of "core shift". Like the aluminum is cast around the sleeves, and then bored offset leaving one side of the sleeves thinner (as in .070" thick) and the other thicker. Our shop rejects blocks all the time for such problems.
The LS2 blocks seem spot on 99% of the time. I personally feel the LS2 is the better of the two.
