difference between L92 engine and Ls3 engine?
Old Feb 15, 2008 | 08:06 PM
redsap05's Avatar
Default difference between L92 engine and Ls3 engine?
I own a 2005 gto with the ls2 and have an opprotunity to get a deal on a L92 6.2L engine. What are the differences between the L92 truck engine and the Ls3 found in the 2008 corvette. From what I can find on the net the truck engine is still an all aluminum block with a 10:5:1 compression ratio. Anyone know the cam specs and compression ration of both engines as I have been unable to find the hardcore specs on the internet. Also what needs to be change to put it in my 2005 gto. Thanks
Old Feb 15, 2008 | 10:06 PM
95FbFormula's Avatar
The intake manifold the compression possibly and the heads on the ls3 are cnc'd I believe
Old Feb 15, 2008 | 11:48 PM
bhop42's Avatar
Intake manifold, accessories, and the LS3 has hollow valves.
Old Feb 15, 2008 | 11:52 PM
blu00rdstr's Avatar
I have LS3 heads, the ports and chambers had a rough sand cast finish.
Old Feb 16, 2008 | 01:56 AM
Johny GTO's Avatar
ls3 has larger testes, but l92 has a bigger coccyx.
Depends who u ask, but it may not be the size but how u use it.
Old Feb 17, 2008 | 03:13 AM
PSM's Avatar
PSM
L92 has VVT and the Ls3 does not
