Stock 799 casting heads whats the valve size ?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
What are the Stock Valve Sizes for the HEads on a 2005 ls2 799 casting heads ? Questions , should i Reuse thises heads or should i buy a head and cam package ?
Its funny you should ask that question, I recently bought a set of LS2 799 heads and had the valves in them measured as I was worried that I had received set of heads from a truck.
The intake valve is 2.00" diameter
The exhaust valve is 1.55" diameter
I have a question for you - what colour are the springs in your heads? Mine are blue with a white marking.
thanks
thanks
