resleeving a 6.0
Old Feb 23, 2008 | 04:58 PM
blackangel327's Avatar
Default resleeving a 6.0
I've searched for 3 days looking for a re sleeve 6.0 thread and I've searched in vain. i want to know who has re sleeved a 6.0 and went with something like 4.125 sleeves? i would like to know the strength i know thats thin but if I'm going to do this I want to do it right, Darton sleeves blah blah, just want to know who's done it before and what they're take on this is? thanks
Old Feb 23, 2008 | 07:59 PM
Wnts2Go10O's Avatar
for the cost.. you could buy an lsx..
Old Feb 23, 2008 | 08:07 PM
of the sleeves or having it done?
Old Feb 23, 2008 | 09:00 PM
Wnts2Go10O's Avatar
the lsx block. if youre talking aluminum why not get an ls7 block?
Old Feb 23, 2008 | 10:22 PM
its 2000 for the LSx and i have an iron block
Old Feb 23, 2008 | 10:32 PM
Steve Bryant's Avatar
LS1 Tech Veteran
The LQ4/LQ9 has iron cylinders that are integrally cast into the block. It is not a sleeved engine, nor is it intended to be by design.
Steve
Old Feb 23, 2008 | 11:09 PM
jermzz's Avatar
The Tosto brother with the red Camaro, you might remember him from pinks VS his brother's blue Firebird. I think they post here too. But anyway. That Camaro had a Sleeved 421ci Iron block. I believe it was 13.0 compression NA and made a tad over 600rw. Ran 9's.
Maybe look him up on here.
EDIT nevermind, it was 15:1. and not even a sleeved block hahah 630 rw. Here's the thread.
https://ls1tech.com/forums/showthrea...034&highlight=
Old Feb 23, 2008 | 11:33 PM
Wnts2Go10O's Avatar
i think ive seen very few sleeved irons but i think its been done. still cheaper to do an LSX block.
Old Feb 24, 2008 | 01:01 AM
i seriously doubt that its more expensive than 2000 bucks, there is a company that will do it for 1499 with donavan sleeves
Old Feb 24, 2008 | 01:15 AM
93ls7z's Avatar
We just finished my 6.0 block after boring it to 4.125. I am going to sonic test it next week and post results, probably here and on my website. It will be a 4.125 bore by 4.100 stroke with L92 heads, so we will see how well it works.
Mike
Old Feb 24, 2008 | 11:26 AM
cant wait to hear how it goes
Old Feb 24, 2008 | 01:35 PM
LS1 Tech Veteran
Here's the results from the sonic test that my shop did on my block before it was bored and honed to 4.031" https://ls1tech.com/forums/showpost....35&postcount=4. For the approximate dimensions now, you'd need to subtract .015" from each measurment. I did a fair amount of research on this subject and learned that my block was average in cylinder wall thickness. I wouldn't have wanted to bore this block any larger. I'll be running normally aspirated, so I feel comfortable with my cylinder wall thickness.
Note: Many cast iron blocks are sleeved and intended to be re-sleeved upon rebuild. I used to be a diesel truck mechanic and I've rebuilt a number of engines that were sleeved.
Steve
Old Feb 24, 2008 | 01:56 PM
Cop Car's Avatar
why would you spend $1500 to resleeve a $400 block when you could go buy a better block that has more bore for $2000.... makes no sense to me at all
Old Feb 24, 2008 | 05:13 PM
because if i choose that I don't have to pay for the machine work
