ls3/ls2/iron 6.0, blocks in a Fbody
I wonder is there any heat issues with the iron block and the ATI cooling fan? Will i need to get a better fan?
I found my ls2 block for 725 shipped, so you figure 325 bucks to save 90 lbs? It's a no brainer. Think how much money it will cost you to pull that weight back out in the long run should you ever want to go faster, and trust me we all want to go faster.
Very good point. But it seems like a pain in the *** to install a ls2..... All parts i can reuse ill just have to tap for the KR sensors? Maybe if someone had a write up on how to install a ls2 into a fbody i would have a better understanding.
