L92 stock valves NOT GOOD
Old 02-29-2008, 11:37 PM
blu00rdstr's Avatar
Originally Posted by See5
FWIW I weighed up some valves a while back:
Stock L92 intake-108.6 grams -- Some non magnetic alloy
Manley 11620 -119 grams- Intake- The Manleys are solid SS
Manley 11621-92 grams- Exh
LS3 intake -89 grams -- hollow alloy and my current favorite (NA) with single springs
LS3 exh same part# as L92 Exh- some non magnetic alloy
Yeah, those Manleys are fricking heavy compared to the LS3 hollow valves I replaced. But those big valves don't have to move much compared to the exhaust. The Comp 921 springs should help some.
You didn't list the weight of the L92/LS3 exhaust valve, got a number to compare to the Manley exhaust grams?
Old 03-01-2008, 06:38 AM
See5's Avatar
I don't remember but it was close to the stockers. I will check next week.
The Manley intakes are the "right" boosted valve.
Old 03-01-2008, 06:43 AM
cam75w/ls1's Avatar
Hmmh, seems the stock 6.0 valves do the same thing. Had a 70yr old customer driving her truck and dropped a valve. Owned it since new and didn't abuse it. This was a 2003 hd 2500.
Attached Thumbnails L92 stock valves NOT GOOD-engine-pics-006.5.jpg   L92 stock valves NOT GOOD-engine-pics-007.5.jpg
Old 03-01-2008, 08:20 AM
fossil's Avatar
I work at a GM service dept and we have not seen any valve failures on the 6.2L as of yet. I did call one my friends at TAC in Detroit and he said the valve problem is no worse than the few we see in the Gen III engines. Just a theory, maybe the factory springs pressure is not enough to pull these big valves back closed quickly enough and maybe not enough seat pressure to keep the intake valves seated? Higher rpms would be even more dramatic. So we then have a possible valve to piston contact issue? And maybe my theory just makes me feel better about my setup also?? Ha Ha Ha
Old 03-01-2008, 08:54 AM
WKMCD's Avatar
Thank you.
Old 03-01-2008, 09:07 AM
Websy21's Avatar
This is jsut great, another thing I need to adress but better that I caught it now rather than later. Thanks guys but what about the exhaust valves?
Old 03-01-2008, 11:20 AM
Websy21's Avatar
I have another new set of the Manley SSs intakes if those can make you feel better?
blu00rdstr above is going to try and blow his up as well
So how much are these and are they a direct replacement or modification, etc?
Old 03-01-2008, 11:26 AM
jay_lt4's Avatar
mine is together. im going to run it.
Old 03-01-2008, 11:36 AM
99ssleeper's Avatar
Originally Posted by bluethunder364
****, I have an order in for a full set of stockers from GMPD that are on the way. Would return them however the web site states that this is a special order item and non-returnable. Now what?? Nothing like buying two sets of valves for your heads.
Will be running #26918 springs
I'm thinking it's better than buying 2 engines for your car.
Old 03-01-2008, 11:50 AM
1BadAction's Avatar
ding ding ding... you got it. the posts above are classic signs of too weak of a valve spring for the valve. engineers seem to love these "barely enough pressure" springs. The problem arises when you get a weaker batch of springs than the minimums they accounted for, or after 60 or 70k the heat cycling weakens them just enough to let the valve beat the **** out of everything.
Old 03-01-2008, 05:48 PM
VX8255's Avatar
Originally Posted by jay_lt4
info from the gm technicians dealer forum- seems some of the 6.2 L92 engines are having problems with the valves breaking off,, some have posted the valve broke right where the keepers go and another stated that is broke off behind the head of the valve,, taking out pistons, cylinders, engines locked right up.
and these are just stock trucks, several have already posted that they have trucks at there dealers waiting for an engine.
i guess those of us with stock valve L92's are screwed, if the valves are having issues on stock truck engines, what will they do at 7000 rpm with high spring pressure
Stock solid stem valves in my car for over 10,000miles so far. LSK Lobes, 921 springs, buzzed to 7,000rpm once and a while, no problems yet.
Old 03-03-2008, 11:33 PM
  #32
Websy21's Avatar
That sounds assuring but I went ahead and ordered the ss manleys for insurance since I'll be pushing some series ammount of boost. Glad I caught this thread, cheap insurance if you ask me!
Old 03-04-2008, 08:58 AM
  #33
Red Goat's Avatar
Default L92 valves
If you havent already bought your springs, you might want to do a search over on LS1GTO and check out some of the broken 918's there. If you are running a big cam trouble could be looking for you.
Old 03-04-2008, 09:02 AM
  #34
See5's Avatar
There are third generation 918s which are all new. New spring, new supplier to Comp.
Old 03-04-2008, 09:54 AM
  #35
Yeahdoug's Avatar
The new supplier is the cause of all the problems
Old 03-04-2008, 09:57 AM
  #36
1BadAction's Avatar
the 3rd generation of springs fix the breaking problems... if they look like this -
you will be OK. end-
Old 03-04-2008, 10:02 AM
  #37
See5's Avatar
I personally think they should have called the 3rd version 919 or something, but who cares?
My friends at Comp assure me this is a far superior spring.
Old 03-04-2008, 10:08 AM
  #38
nahasapeemapetalon's Avatar
What about titanium valves?
Old 03-04-2008, 10:18 AM
  #39
1BadAction's Avatar
Default after some investigating...
I find it interesting and amusing that this Yeahdoug guy shows up any time there is a shitstorm about valve spring problems. I wonder what company he works for
Old 03-04-2008, 10:24 AM
  #40
Yeahdoug's Avatar
You're right. I'll stay out of any spring related threads since I know nothing about springs or valve spring related issues.
I'll just let all the mis-information about springs continue to spread. Doesn't matter to me. You obviously know more about them than me. When one of my Pro-stock customers calls me today, I'll forward it on to you.
Sorry for the Hijack.
Like others have said. Part of the problem is not having enough spring to control that heavy *** valve. If you want to run beehives try installing them a little tighter for some extra seat pressure (keeping enough clearance to coil bind) or just run duals (patriots, 921, etc)
Quick Reply: L92 stock valves NOT GOOD
