Ls6 Heads On A L92 Block
crank, forged rods, LS6 CNC ported heads, and a FAST 90 intake on a L92 4.07 block. This is in a 99 C5. For this L92 block I need Pistons: 4.07 with valve reliefs for the LS6 heads. Cam: new for the front cam sensor. New front engine cover for the cam sensor? New Valley Cover? Wiring harness extension for the cam sensor.
Is my LS6 oil pan OK? Rear Cover? Timing chain? Oil pump? What else?
Thanks for any input.
What are you guys using for a high performance timing chain? I have a Crane double row adjustable now, that's not going to work with this new block. Are there any aftermarket sprockets/chains that are better than the LS2 chain.
Oil pan OK
Rear cover take off your old block
Make sure wiring harness extension for knock sensors (2)
Make sure head gasket is for the larger bore(no LS6 size)
And all the normal little stuff
They have double roller LS2 timing sets
