What would you do > swapping rockers
Swapping in Yella Terra Ultralites. I was wondering what you would change with my current setup while the installation is being done. With the swap, would you change any of my setup below without causing me to have to pull the heads or front engine cover:
AFR 205 heads 60cc chambers with GMS head gaskets; Comp X'er cam 224/228 .581.588 114LSA 1*; Comp 'R' lifters (850's); Comp 5/16 Magnum hardened pushrods.
The lighter the geometry the better, of course, but, I don't think I could change much other than the pushrods without pulling the heads.
