Titanium valves?
Old Mar 25, 2008 | 10:37 PM
2000_SS's Avatar
Originally Posted by xfactor_pitbulls
I dont doubt what you are saying, and you sound like a sharp guy. I just wanted to warn the lessor knowledgable ones reading that just because the add says titanium, doesnt mean it really is. IE. if the set of valves are $100, you can bet they arent Ti. About what is that guy charging to rework valves, our of curiousity sake? I ask, because I know of two guys that do it locally and its not really viable.
lol, that's me! j/k, i know enough not to trust ebay and i know the differences between Ti and Ti coating.
i'm just wondering why i would need Ti exhaust valves to suit a cam if Ti exhaust valves would be a problem. in other words, why spend the money on a cam that requires a valve that won't last? why not Ti intake valves and some type of other lightweight exhaust valve? what's the closest subistitute, hollow-stem, sodium-filled, inconel, what? i won't be running boost, and N20 is only a possibility in the distant future, and if it come to fruition it would only be about a 150 hit.
Old Mar 25, 2008 | 10:49 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ I like inconel for exhaust valves. It dissipates heat extremely well, is still decently light, and is readily available at a reasonable price.
Old Mar 26, 2008 | 06:30 AM
2000_SS's Avatar
well i just found out the set of ET heads i want to run are in the $4000-4500 range all of the discussion is moot unless my dirtbike sells
Old Mar 26, 2008 | 06:31 AM
Stang's Bane's Avatar
If you are running N/A you can run the factory exhaust valve. It weighs roughly the same as the much larger TI intake valve.
Old Mar 26, 2008 | 09:13 AM
LT-4Play's Avatar
Here is a pic of the Lingenfelter 383 that swallowed a Ti exhaust valve, save the money on the exhaust side and get a sodium filled. I'd hate to see this happen to someone else. This may have worked on other motors but why take the chance? After the motor was built I talked to a guy who races vintage Corvettes and they had the same issue there motors were swallowing Ti exhaust valves. I'm not saying that it hasn't worked in the past, I'm just saying why take the chance.
Old Mar 26, 2008 | 10:54 AM
OWN3D BY MY PROF!
^ That's quite the carnage picture there. I like how it completely trashed the block.
Old Mar 26, 2008 | 05:07 PM
2000_SS's Avatar
holy sh*t that picture makes me wanna sell the car and buy a Huffy
i'll probably go with a Inconel ex valve and Ti intake....this is all budget-permitting though
thanks for all the help guys. this is why i love this board
Old Mar 26, 2008 | 07:52 PM
KCS's Avatar
KCS
Moderator
What seat material was he running? Be-Cu?
Old Mar 26, 2008 | 09:21 PM
Unless you are going to run boost, there is no reason to run the inconel. For a strictly NA engine, the factory hollow stems are great. You could run a 100 shot on them also with no problems.
That is what is going in mine. And no I did not scrimp and save. I have more in my factory ls7 heads than the price that ET quoted you. I spent money everywhere it would make me power, but no where it wouldn't.
Old Mar 27, 2008 | 08:39 AM
LT-4Play's Avatar
They where copper berlynium (sp?) The valves were 1 piece Ti.
