lsx 484 cui
to reduce friction.
and 1400 Series GRP connecting rods in a length of 6.00 inches Diamond pistons were CNC-milled for proper deck height and valve notch depth, yield a static compression ratio of 14.5:1, and are serviced by 0.062-inch gas ports that scheme against Diamond Hellfire rings and intake custom super victor jr ls7 with flange 4500 and carb holley 1250cfm and msd triger Jesel supplied the 0.941-inch
diameter tie-bar roller lifters
and the 1.85:1 shaft-mounted
rocker system and Double-taper Trend pushrods
feature a 0.065-inch wall
and an overall length of
9.50 inches and dry sump and heads c5r full ported and valve 2.220 1.65 and i want Short versus normal damper hubs: the longer of the two is used with the Jesel belt drive to eliminate the oil pump. The installation of a Jesel belt drive necessitates an external oil pump. The longer hub makes up the difference when using the Jesel belt drive. Lunati solid roller cam, for instance, was ground with 284/304 degrees of duration at 0.050-inch and with a 110 degree lobe separation. Lift on both valves is a stupefying 0.980-inch. To contain this jiggery, Stealy specified Jesel 0.941-inch diameter tie-bar lifters and its 1.85:1 shaft rocker arms
can you help me please how mush total price
thanks mohammed from kuwait
I wouldl get in touch with these guys. This motor is pretty close. Price shoudl be similiar.
I know of another one that you may could get your hands on also.
kuperf@aol.com
Kurt
to reduce friction.
kuperf@aol.com
Kurt
Andrew
i do reckon it years to come a ls engine will be up their with the max effort engines of sbc and some bbc-even though the ls engine has been around for just over ten years-their is still more to come just like all the research and trial and error thats been done on sbc and bbc over the last 20-25 year's
would it also be fair to say that a ls engine is a bit more expensive because of the following the sbc and bbc has??
Nick--
Nick--
But I think this subject has been talked about to death on every forum out there.
like the avatar.
If time was on my side (it was not) going with a 650RWHP tall deck 484 CI LSX motor was the way I originally wanted to go 1.5 years ago, but couldn't wait that long, and knew I could make 700+ rwhp with the set-up in my sig. for less $.
like the avatar.
maybe but things only get better in time and more research
Nick--
to reduce friction.
Building an all out NA race engine though is not everyone's cup of tea and the sheer amount of attention any true race engine needs has to be communicated to any potential buyer so they know what they are getting into or an appropriate engine can be designed for them with the maintenance they can handle.
.980 lift though is not low maintenance!!!
There is war going on in the area between LS7 guys and some old Camaro, factory big block, that is running big cubes. Heared it's 600+ci, bored and stroked. It came from factory with big block. This is why he was able to run the class.
Domination is the intent of the requester. Money $$$ is not an issue with those guys. No wonder they want the highest NA HP small block.
What he said and your welcome ERIK, and I should be getting my bad boy forged LS6 347 blower motor you recently built this early winter dyno tuned on Monday (April 7). Stay tuned my friend and hope all is well!
