new cam specd out for the 408
Old Apr 2, 2008 | 08:41 PM
xdanny510x's Avatar
Default new cam specd out for the 408
well my builder just called me back today and told me that he has once again changed my cam for a l92 stroker
First of all i was gonna go with a ms4 camshaft my choice jeje but then i was readin threads and i guess i had picked out a bad one lol .. Then my builder called me and told me to go a different route along the line of 240 252,114lsa and then called me back today and said with my stall and gears that i have he changed it to a 230 242 114 lsa since its going in a truck i need somethign to get it up faster rather than having power kick in towards the upper rpm band ..
Old Apr 2, 2008 | 09:36 PM
1ORANGEWS6's Avatar
I'm looking for a cam myself for my 408 L92 setup. Good luck getting people to respond there are quite a few smartasses on here that will tell you to do a search like you haven't done that already.
How do you think your tranny will last behind that beast?
Old Apr 2, 2008 | 09:40 PM
xdanny510x's Avatar
if i dont get on it lol and probably just race from a roll probably 3 months LOl i give it till summer ... I guess im just gonna have to watch the trans temp and keep it cool
Old Apr 14, 2008 | 09:19 AM
hymey's Avatar
A guy on the forum(WKMCD) runs a 234 240 112+0 and works good in a 408/L92 combo
Old Apr 14, 2008 | 10:46 AM
Caveman's Avatar
10 & 11 Second Club
I am putting a Comp 236/248 114 lsa in a L92 427. Same split that your going with just in between the 2 cams you listed. I bought the longblock with a 250/262 113+3 cam and that is just way too much cam for a street driven car.
Old Apr 14, 2008 | 03:11 PM
Blindmelon's Avatar
Here is what SDPC told me to use with my L92 heads.
http://www.sdparts.com/product/CRA14...850590114.aspx
Old Apr 14, 2008 | 04:12 PM
99blancoSS's Avatar
So what stall do you have in it?
Old Apr 14, 2008 | 04:44 PM
Blindmelon's Avatar
The above SDPC cam is whats in my LS2 with Stage II L92 heads all Manley stuff. You will find cams larger then that in a heavy truck don't work so well. That is about as big as you want with big torque on mids & low end. Different story if you had a 3600 lb car not a 4600 to 5000 lb truck. All the SS Trailblazer guys have ran faster with the smaller cams. I should run low 12's with it all motor & low 11's on nitrous with my built motor.
Old Apr 14, 2008 | 04:52 PM
94 guy's Avatar
if your doing a truck give futral motorsports a call. he does alot of trucks.
Old Apr 15, 2008 | 05:55 AM
WKMCD's Avatar
Thanks!
https://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
Old Apr 16, 2008 | 01:20 AM
xdanny510x's Avatar
IM RUNNING A 3000 STALL
