check engine sing ls7
Hi There
I Had Install A Cam On My C6 Z06 And I Had That Check Engine Light On My Dash Board I'v Tried To Ignore It Form The Hp Tuner But It's Keep Coming On All The Time What Do You Gays Think Of The Cause I'v Tried To Disconect The Map Sensor But It's On Again
I Need Some Help i have that code no. p0106 on the hp scanner
Need more information...
I think it can be caused by a cam being to big causing vacuum problems.
Bring up your idle some RPMS
Also check the vacuum lines on your intake
And switch the gay font
It's probably picking up the lope of the cam as misfires. I'm not a tuner, but i think they disable the computer from detecting misfires to eliminate the code from constantly popping up.
I'd get the advise of a tuner before you do anything.
