Dynoed my 402ci l92,l76 today.
Not saying that's what happened here but the MD's sure make it easy. There was an L92 build last year with grossly inflated numbers that couldn't be backed up. The owner later found out the car actually made almost 80RWHP less that he was originally told.
My car weights 3480lbs with out me in it. I weigh 215-220lbs. about 3,700lbs with me.You people make a great point,he did build the motor and it would be interesting to see what a different dyno would say. On my last set up he would have no reason to fudge any #'s because he had nothing to do with any of the build and the car at 3,700lbs was near 10's N/A.
You boys have me wondering,I found a dynojet about 10mi from me and I'm calling them tomorrow. Now I did dyno in the past on an old set up at speed inc and hardcore's dyno jets and the mustang dyno was 30hp lower from the lowest dynojet #'s. so,now we'll see and I'll post both graphs side by side for you all when It's over. I hope there was no fudging on this motor. I'll try to take care of this with in one week or less. TI'LL WE MEET AGAIN.
30TH TA-two different dynojets but still verry close. I would be happy if the jet shows the same as kirks. I just don't want to think Kirk would try for higher #'s.
On my graph it showed my car at the correct weight. This was the only run down the track I got. I have no roll cage and was only doing 60foot runs trying to get it to hook. The car spun out of the hole and I hit the rev limiter also in first gear. Maybe this was not a great run to tell,but it was all I could get because they told me no more runs. This car will go 10.8 n/a when I get it togeather.
#32
Guys, Hes trapping close to 128mph IN A 3700+ CAR. Your going to need more than 470rwhp to do that in this weather. IMO the 517rwhp he made on the stang dyno will be close to what he makes on a Dynojet. I already proved with the H/C 346 I bought from him that the stang dyno he uses and a dynojet will show similar numbers. Heres a list i put together of similars 402/408 6 speed cars and their rwhp & ET & mph. All of these cars are 3600lbs+ .Of course these are all different drivers and different tracks, but I think his 517rwhp & trapping 127.xx is right where it should be at his weight.
speedracer5532 - 402 527/465 10.81@130 1.65 3700lb
Nickn20 ARE 422 515/500 10.98@128.6 1.70
marine02SS - 408 519/475 10.71@127 full
1BDHWK - 408 518/??? 10.77@127.11
Dustin Butts - iron 402 510/477 10.85@127.5 1.58 3600lb
Rampant - 412 LS2 511/483 11.03@127 1.48 60' 3880lbs
Bill00Formula friend 402 xxxxx 11.05@127 1.7 60' full
Slow Trap - 408 511/483 11.11@125 1.63 60' 3800lbs
JDP 505/ 11.2@126.7 1.8 FULL
mr 35th - 408 534/486 11.13@125.86 1.6 3800lb
EZSS - 402 518/473 10.94@124.5 full
98Z28Cobrakiller - 402 501/452 11.36@125.2 1.78 60' 3800lbs
Camarokid94 - 402 501/489 11.54@125.73 1.91 3660lbs
Orange Peel - 402 506/452 11.88@123.8 2.0 60'
Mr. Lous - 402 531/481 11.9@117 7100' DA full
CuNfUsEd - 408 502/476 12.0@124
#33
I ran at lapeer dragway. I also made one other run,but shutdown to not break out past 11.5's....no roll cage. I ran 11.49 at 126.2 shutting down early. I called the shop and they can't dyno my car ti'll mid next week. A friend of mine was there when we dynoed the car and on the motor closed cutout it made 497hp and I told the tuner I wanted 500hp closed cutout was my goal. My bud said if he fudged the #'s he would of done something like I can tune somemore and he would of got me the extra 3hp(fudging)I wanted. 497HP threw a B&B catcack and 517hp cutout open. Im looking to return to the track this weekend to try to tune my suspension and get a better time.I also noticed k-tech's 427 camaro ran 10.85 @126mph I think it dynoed 520hp on the same dyno I did. so the 126mph must mean it is actually only making 450hp.lol THANKS FOR THE SUPPORT 30TH TA.
#34
I ran a 10.159@ 135.86 mph with 539 rwhp on a supercharged fbody. My raceweight was 3400.
Mike c's numbers don't sound to far off for his weight and mph.
The dyno numbers were on a dynojet.
What gear are you running in the car Mike c?
#35
I don't need a jet,I've been on two before the stang dyno and both had my old set up(first set up)one at 424hp 407tq and the other had me at 420hp 402tq. I then went to the stang dyno and got 370hp 350tq....why would I want to go wast my time on a dynojet. I went to the track today...NOT GOOD,the 26'' slick will not hold my car anymore. On my 346ci I was 1.42 60 foots N/A. This motor same slick 1.55 60's best and 1.77 worst. I spun my way to
1.56 60 foot
7.072 1/8et
103.57 1/8mph
11.001 1/4 et so close to 10's N/A
127.82 mph.
todays temp 61deg with a 20mph head wind.
I tried everything from different shock combos,less tire pressure different luanch rpm's and could not find the proper settings.
I'll try again with some 27'' or 28'' slicks and work at it again.
well...I'm done with this post ti'll I get it worked out.
1.56 60 foot
7.072 1/8et
103.57 1/8mph
127.82 mph.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#37
FWIW, I dug up the Hp-weight-trap speed equation. For a 3700 lb car, the engine must make the following Hp in order to trap speed @
115mph ---> 439 Hp
120mph ---> 499 Hp
125mph ---> 564 Hp
130mph ---> 634 Hp
Hp = (veh wgt) * (trap speed/234) ** 3
vehicle wgt is in lbf.
trap speed is in mph.
115mph ---> 439 Hp
120mph ---> 499 Hp
125mph ---> 564 Hp
130mph ---> 634 Hp
#39
I DID IT 10's N/A. I went to the track today to play with the suspension,but no mattae what I did a 1.49 60 was the best I could get.
Last motor I was 1.42-1.44 60's. I think a 27'' tire will be added
today I ran 1/8 mi all day but full 1/4mi on the last run.
BEST 1/8 mi
1.49 60
6.970 1/8et
105.76mph I was happy with this.
ONLY 1/4mi RUN AND I hit the rev limiter in 1st GEAR.
1.504 60
7.019 1/8et
104.83
10.865
127.70
car is 3,720lbs with me in it.
I now have a trans whin(sounds like a supercharger) and a leak so I messed up something.
I guess I'm done posting on this ti'll I'm fixed,get a fast intake and maybe loose 50lbs or so. I wanted a 10sec street car and I got it.
Mike c.
BEST 1/8 mi
1.49 60
6.970 1/8et
1.504 60
7.019 1/8et
104.83
10.865
127.70
Mike c.
