Please help-solid roller lifters. which ones????
Old Apr 26, 2008 | 08:12 AM
89lx-ls1's Avatar
Default Please help-solid roller lifters. which ones????
i have talked to many places and no one seems to know what i really need.
comp cams 276-773 292-748 on a 112
all pro heads ported by Weld tech2.200 intake and 1.600 exh.
14 to 1 comp t&d shaft mounts
if you need any more info let me know. i am really looking for a part number or someone who i can call who really knows what the are talking about.thanks
Old Apr 26, 2008 | 08:48 AM
ls1 joe's Avatar
I have had good luck with the .937 Jesel lifters, key way or tie bar you can't go wrong. I think Morel makes a .904 Lifter also.
Old Apr 26, 2008 | 09:26 AM
89lx-ls1's Avatar
i know the jesels are great peices but what is with the .937 and the .904 are they different diameters? or what?
Old Apr 26, 2008 | 09:39 AM
ls1 joe's Avatar
.937 is the lifter diameter, as well as .904 is the lifter diameter, stock lifters are .842. The .937 and .904 are not drop in lifters and require lifter bore maching as well as the bronze sleeves that go with them. The larger lifters can handle more load as they have a larger roller wheel also. You will be looking at $2700 for the Jesel lifters,$600 for the bronze bushings and possibly $600 for the lifter bore machining and honing.
Old Apr 26, 2008 | 10:08 AM
ssfast99's Avatar
holy ****, i just saw 2700 for lifters. i just got my block for a 13 to 1 comp solid roller and did not realize it cost so much to do it right. it is going to take longer than a year to build my motor.
Old Apr 26, 2008 | 11:02 AM
racer7088's Avatar
Arrow
It depends on how much lobe lift and spring pressure you have and how high you are planning to turn it. You can certainly run .842 lifters too. There are several lifters that can work again depending on what you are doing.
Joe's setup above is the best by far with the bigger Jesel lifters but it isn't necesarily a must do for any solid roller deal. 90 per cent of guys do not run a setup like that but if you can swing it, it's probably the best.
Old Apr 26, 2008 | 11:44 AM
89lx-ls1's Avatar
ok well what is an .842 lifter i can use
Old Apr 26, 2008 | 01:49 PM
JBM's Avatar
JBM
.842 Morel non-tie bar lifters here. Im using the Jesel dog bone lifter guides, but they are, for the most part, unnecessary.
Old Apr 26, 2008 | 01:51 PM
JBM's Avatar
JBM
And we wonder why guys go FI.
Old Apr 26, 2008 | 07:15 PM
racer7088's Avatar
Thumbs up
Again it depends on the lobe lift you want. For lower lobe lifts I use the Morel drop ins and they are a good price.
For bigger lobe lifts over .400 I would do the Crowers or COmps etc.
For way bigger like over .470 Joe's big Jesels are probably the best since you are probably also running much more spring and turning more rpm.
It all depends.
Old Apr 26, 2008 | 09:27 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
What makes a set of .937 jesel lifters 6 times more expensive than the standard .842 morels? I find the only possible explanation is price gouging. Unless they are made of pure titanium or something odd.
Old Apr 27, 2008 | 01:15 AM
racer7088's Avatar
Arrow
Also just the much much smaller numbers of them being produced and Jesel uses the best of whatever they can get without much concern for cost so it does end up much more expensive. Better for sure, but not cost effective till you get to the point where you need them and then they may save you a lot of money over a set of lifters that fail etc. but were cheaper initially. I agree that they are crazy expensive though.
Old Apr 27, 2008 | 10:59 PM
OWN3D BY MY PROF!
^ I was thought of production numbers after I posted. I don't know about the materials they use, but 6x the cost is rather insane.
Old Apr 28, 2008 | 12:28 AM
racer7088's Avatar
Yeah I agree with you and that's why it's hard to sell Jesel on any normal build.
Old Apr 28, 2008 | 05:29 AM
aNuBiS's Avatar
It all depends.
These lifts you're refering to, are they @50 ?
Old Apr 28, 2008 | 07:27 AM
89lx-ls1's Avatar
why would you use some jesel tie bars if they are non tiebar lifters
Old Apr 28, 2008 | 08:21 AM
AINT SKEERED's Avatar
Lobe lift as in with out rocker ratio. the actuall lift of the lobe before you multiply it times 1.7 for the rocker ratio or whatever ratio you run on it.
Old Apr 28, 2008 | 08:23 AM
aNuBiS's Avatar
Ok, thats what I thought *phew*
Old Apr 28, 2008 | 09:25 AM
racer7088's Avatar
Thumbs up
Yep that's total lobe lift.
Old Apr 29, 2008 | 07:30 AM
JBM's Avatar
JBM
Lifter guides. The lifters are not connected in pairs with a tie bar. The Jesel part replaced the factory plastic lifter tray.
