A new, mild cam I need to get for my 402
Well guys, I was originally going to do this:
I ordered a brand new 402 shortblock from Texas speed... and I was going to re use my Torquer v3 cam and PRC 5.3 stage 2.5 heads (which came from my stock LS1 346 with 90,000 mils on it) which had only 150 miles on them(the heads anc cam).... the 402, however was brand new...
So I finally found out why my 346, that originally had the torquer 3 and 5.3 heads on it seized up... One of my caddy lifters, which was brand new, and had been soaked in oil. had failed and dumped some short dowel looking rod into my motor, which had caused my engine to not run....
The lifter piece had circulated into my engine and destroyed my reluctor wheel, my camshaft lobe, some nicks on my rocker arm, and so forth...
So the caddy lifters suck ***! Im gonna have a word with GM, brand new lifters that were properly installed should not fail!!!
Basically now I need help with the selection of thw following...
New lifters that will NOT fail on my after correct installation and soaking in oil... and a new camshaft... I wanna go streetable and something thatll have off idle power... Im a M6 with Aluminum FW and Moser 12 bolt, 3.73s
I do want to make over 500rwhp, but I know its not gonna happen, unless I probably get a fast 92/92 and maybe some kooks headers...
as of now I have a LS6 manifold and ceramic coated pacesetters, ORY andd magnaflow catback....
I made 432 rwhp before with the H/C Tv3 LS1, so I do wanna pick up significant power over that, but I am fine with under 500rwhp, as long as I have a good increase of power throughout all RPMs.... or if not that a very streetable, car. It is a Daily driver thatll see city, highway, long drives, few times a year track days/road racing and at leats once a month 5 - 7 passes at the dragstrip...
So basically if someone can spec me a cam for a good , off idle power car and to make as much power as I can, with these manners, plus some good lifters... lastly I am willing to go fast 92/92 if 500rwhp or near that can be obtained with such a specified , good daily driver cam....
My mods are
402 shortblock, -10cc pistons, Eagle crank and rods with ARP bolts , hardened pushrods, ported LS6 oil pump, YT rockers but there has been small nicks on them from metal circulating in my old engine so I may go back to Harland sharp rockers, all suspension, Rebuilt T-56. LS7 clutch with aluminum FW, which will soon be replaced with McLeod twin disc or SPEC 3+ Moser 12 bolt, aluminum Driveshaft PST, 25% underdrive pulley(powerbond) now with ARP bolt. Pacesetter LT headers, magnaflow catback, ORY, Lid, home ported stock TB, 85mm MAF, LS6 manifold..
car is 2002 Z28...
I think that is all... please chime in. thanks
My mods are
car is 2002 Z28...
I've got a Comp XER 244/248 .612/.615 112+2. Any bigger , the way I understand it, and over lap and DCR can become a problem. Patrick G is great on specing out cams.
500 RWHP with a Fast and your TSP heads should be doable, no problem. Check the link below for my dyno.
https://ls1tech.com/forums/dynamometer-results-comparisons/911927-56-rwhp-gain-induction-change.html
https://ls1tech.com/forums/showthread.php?t=911927
I would use the FAST 92/92 setup if it were my car. There is a HP/TQ gain over your LS6 intake. For a mild built engine as a DD I would use a 238/246, .622"/.622", 113*+ 1* cam from Ed @ www.thehpfactory.com (Or just click the banner in my sig!). I would also highly recommend him for tuning your car as well. Here is a link to my cousins C5 Vette that he finished for us, https://ls1tech.com/forums/showthrea...403+our+latest . This car is my cousins DD and has a bigger cam than what I recommended for your build, plus alot less overlap @.050" duration.
I have a 402 6 speed 3.42 gears, B 4 this mustang freak tried to tune it the first time, it popped 450 @ the wheels. Then he tinkered with it a little and it did 482. Though it ran like **** !
Afterwards had a speed dentisy tune done and it's wild !
231/237 .598/.595 115 LSA +2 , Fast 90/90, cheap ported 317 heads, Dynatech 1 3/4 headers, Flowmaster catback (open chamber :-) )
For Drive ability, I would not go bigger. Just personal preference.
Even this cam has some Bucking, and little annoying idles issues . However it picks up nicely in 6th gear @ 60 mph with no trouble. Really Wakes Up on a hard WOT pull.
Now I went S60 3.73's and even pulls better....
Check out the sticky about the 400+ ci set-ups it has all kinds of combos and reviews I'm sure you can find some useful info in there.
something like a 231 237 sounds good. or maaybe even a 234 240 cam or something like that, but I dont wanna start getting past the 240s, its gonna sound like itll be a peaky cam if the duration gets in those numbers again...
I was gonna keep old heads and cam to put on my 402, now I need a new cam... but a fast 92/92 at the moment is killing my budget, since I just spent 5k on a new 402 shortblock
I know what you mean, the FAST is a pretty good chunk of change...
I started out with the LS6 intake then switched over to the FAST. Not too much of a PITA changing it in the car..
Do a little searching to check out various dyno graphs and they'll tell the story about the torque and HP curve of some cams on this site.
Good luck !
Good luck !
Choose a cam with 6 degrees or so of split. If you've got a good tuner go with a 112 lsa with 2-4 degrees of advance. If not go with a 114 lsa. As a rule of thumb a 402 will take 10 degrees more cam than a 346 to give you similar drivability. Example: A 224-230 in a 346 will drive about ike a 234-240 in a 402. I run a 234-240 112 +0 but that's with L92 heads at 11.4:1 compression. No reason though that that cam wouldn't work very well with your heads but with 4 degrees of advance. Whatever you do, don't over cam. Your heads won't keep up with it.
My $.02
I made multipe threads for when I was doing my head/cam swap... talked to sevral people and texas speed. No one told me this...
So Wtf man?! Im so pissed, that retatded bits of info are just NOW reaching me. that maybe I could have potentially saved my old LS1.
I havent driven in 90+ days, I miss my car so much. Im so mad right now
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Its not a caddy lifter issue, its all rollers.
Alot of times they have some sort of waxy coating that gets into the roller needle bearings, and makes them stick. The use it to keep them from rusting or something. They've been that way for years, heck decades.
All roller lifters, regardless of name brand, or if they're solid or hydraulic, need to be cleaned in solvent, and you have to make sure the rollers spin freely.
