whats the difference between l92 and ls2 blocks?
Old May 19, 2008 | 12:38 PM
iwanta-v8's Avatar
Default whats the difference between l92 and ls2 blocks?
i searched around the forums and i couldnt find a definite answer to this but whats the difference between the l92 motor vs ls2? i see alot of people go with the ls2/l92/l76 combo, why not just get a l92 longblock with a l76 intake? is there flaws in the l92 block. and is a l92 just a stroked ls2?
trying to decide which block/head combo would be best to start off with, my goal would be 500-600ish whp n/a daily driven, and if there are major difference between them for hp wise.
Old May 19, 2008 | 01:30 PM
91Z28's Avatar
The L92 uses the same stroke as the LS1, LS2, LS3, LQ9, etc at 3.62. The difference is the bore is 4.060" instead of 4.00" on the LS2. There are some other structural differences too.
Old May 19, 2008 | 01:39 PM
iwanta-v8's Avatar
so either block would be good too start off with minus the bore difference?
Old May 19, 2008 | 03:04 PM
Gripenfelter's Avatar
I was wondering the same thing. Why would you go with an LS2 or LQ9 block over an L92 block?
Old May 19, 2008 | 09:55 PM
KCS's Avatar
KCS
Moderator
Cheaper and easier to find in a junkyard. I got a LQ9 block for a little bit over $200.
