Question stroker 418ci short block
Old May 20, 2008 | 07:51 AM
mohammed_k81's Avatar
Cool Question stroker 418ci short block
What heads and cam do you recommend?
No forced induction No Nos Just a weekend drive racing all the races will be from a role I don't care about track time just want a car that pulls hard
Could you give the best size heads and cam recommend for this Set up.
I have the fast intake clutch tire just confused about the heads and Cam
Thank you
Old May 21, 2008 | 02:07 AM
Need the best compression ratio for street
Would I for AFR Mongoose 205cc FULLY CNC 66cc Chambers
Or AFR Mongoose 225cc FULLY CNC 66cc Chambers
Old May 21, 2008 | 07:58 PM
Mr.MartyStone's Avatar
Definitely the 225's at the minimum.
Old May 21, 2008 | 08:23 PM
JL ws-6's Avatar
Race your car!
11 to 11.5 to 1 compression, cam in teh mid to high 240's for duration, I'd try to keep the lift at 600 or less for a street car just so the valvesprings don't get hammered in 5000 miles.
Et 225 or 240's, tfs 225 or 235's would work.
