Boss Hoss motorcycle LS2 mods help
I just purchased a new 2008 Boss Hoss motorcycle with the LS2 engine from California Boss Hoss.
They will be removing the stock engine for disassembly and rebuilding with top shelf components and will also sport NOS. I have the goal of 600+hp and 8000rpm minimum before NOS. The bike has a wet sump, and I want it to be durable and last 100k or more before rebuild required. I only want minimum maintenance such as valve lash, etc. The only thing the engine has to spin is an alternator; no power brakes or anything requiring vacuum or good idle. I'm fairly sure it has the GM ECU.
The LS2 is new territory as we previously used the 350 and 502 Chevy and weren't 100% sure on how to proceed and would appreciate any advice. We were thinking AFR heads, light weight forged pistons, MSD coils, etc. The bike weighs just under 1000lbs and looking for mid to top end performance; How would you build the engine???
Thanks
Ricky
I can't be much help except to tell you that the MSD coils aren't worth the money. They've shown zero hp increase on the dyno even above 7k, and a lot of people have had them fail frequently. Stock coils are cheaper and, from everything I've read, much better.
AFR heads are great, but Trick Flows appear to be the best for max top end power.
Use the lightest crank, rods, pistons you can buy.
ETP 225 heads and a cam with a good idle. You aren't going to want a nasty lope on a bike.
Hell make it a stroker...
There are a ton of head/cam setups on here making the kind of flywheel power you are looking for. Just find one you like. As for the bottom end, I would stick with a stock crank, and get some good Callies or Lunati Rods and some Diamond pistons. Stock cranks have gone 8's in cars so I can't see you breaking it on a bike. It is going to be tough getting 8000 RPM with our intakes, but 7000 should be pretty easy.
-Geoff
You may look at one on the factory website though,
http://www.bosshoss.net/view_bike.asp?x=BHC3LS2
I really appreciate all of the advice so far, Thanx
The LS2 bike is expensive at $52K; I'm dropping around $75K on this custom build which is crazy, but I want it bad. I could buy a new Dodge Viper or ZO6 for that kind of money.
What about the factory ECU and intake? Should I opt for the FAST EFI system and intake??
We will not be using the factory exhaust, a custom one is being built now.
I will have 2 sets of rear wheels, one sporting a drag slick for 1/4 mile track and the chromed version will sport a 300 street tire. I know that I will still be able to break the tire loose at will.
I'm hoping that it will be the fastest street legal 1/4 mile Boss Hoss in the country, and very curious to know what kind of times and speed it will be capable of performing. 8 sec/200mph??
The FAST intake manifold makes impressive numbers for motors spinning up to 7k RPMs... any higher than that, and you'd want a sheet metal intake, or maybe a Vic Jr/elbow setup if you could fit it.
Good luck, wear a helmet, and a foam body suit while you're at it! Death will be riding right behind you at all times!
I'm also with the above poster btw. Ride it first and see if you need the nitrous. Having the back end of a car fishtailing at 100mph is one thing having the back end of a motorcyle fishtailing even harder at 100+ mph is quite another.
You can do whatever you want in first, and assuming that the 2008 LS2 bike is geared the same as my 2007 zz4 350 Boss Hoss, it will allow me to get...
130mph @ 6000 rpm redline with zz4 350
173mph @ 8000 rpm redline with LS2
195mph @ 9000 rpm(I'm allowed to dream)
Basically, when confronted with a turbo Suzuki Hyabusa, etc, I want to take no prisoners by not having to shift.
Also, I plan to run the bike at the track and don't want to redline before reaching the 1/4 mile; don't want to shift to second.
There are quite a few Boss Hoss's running around with 605/632 cu.in. Merlin's, one of which I saw in Sturgis sporting NOS and just over 1100hp. Impressive, it shakes the ground. As impressive as that is, they are most likely limited to 6000rpm.
Basically, 8000rpm will allow me to "Stomp some *ss".
