C5R vs LS7
Old May 27, 2008 | 12:35 PM
2001CamaroGuy's Avatar
Default C5R vs LS7
Sorry to "re-ask" this but I could never find a CLEAR answer. On a 427+ CI engine, are the C5R heads (once ported) any better than the LS7 heads?
Based on what I COULD get form searching:
- the C5Rs come "as cast" vs the LS7s are already ported (so can not compare "stock to stock").
- the C5Rs have really small chambers (which would require either some major chamber work or a deep dish piston).
- the C5R heads will work with the LS7 intake (seems companies just drill the LS7 intake bolt pattern)
- exhaust flange design is the same
Old May 27, 2008 | 05:58 PM
LSX-PWR's Avatar
I am wondering if the the ls7 rocker arms and plates can be used on the C5R heads?
Old May 27, 2008 | 06:16 PM
AU N EGL's Avatar
C5R block info
https://ls1tech.com/forums/generation-iii-internal-engine/310618-c5r-block-info-vs-sleeved-blocks.html
Basic engine spec differences
http://www.corvetteracing.com/cars/c...ne_specs.shtml
The C5R heads have a taller deck and need a Kinsler manifold
http://www.sdparts.com/product/12480...numRacing.aspx
http://www.kinsler.com/page--GM--17.html
Old May 27, 2008 | 06:30 PM
needadvice's Avatar
Don't the ported LS7's whip the C5R heads?
Old May 27, 2008 | 06:53 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ In flow numbers, but that's not all that matters. C5R heads are proven performers. LS7 heads haven't really produced any really fast cars yet.
Old May 28, 2008 | 06:30 AM
AU N EGL's Avatar
The C5R heads are designe for higher velocity air flow, not more volume as in the LS7 heads.
The C5r heads are for loads of torque. A properly build C5r block with the C5r heads can and does produce torque in the 630-650 lb ft range, but only 580-600 bhp with about a 6200 rpm red line.
Put on the LS7 heads and reverse those numbers and up the red line a bit.
Different heads for different results.
Old May 28, 2008 | 08:49 AM
needadvice's Avatar
Sounds like the LS7 heads are much better for a street/strip car than.
But those C5R engines are making those great numbers because they don't have the horrible air flow restrictions like we have we these plastic LS1/6/7 intakes. They have an intake that actually allows all or almost all of those cfm's the heads can flow to be used by the engine. Big difference.
Old May 28, 2008 | 09:01 AM
Stang's Bane's Avatar
More likely 99.9% of builds that use c5r heads are big compression and full race engines.
FWIW any intake port on a cylinder head is going to "lose" flow when you put an intake manifold on it.
Old May 28, 2008 | 09:19 AM
needadvice's Avatar
Yeah, thats why I said "almost all". But clearly the plastic intakes we have essentially takes a badass 400cfm LS7 head and turns it into an L92 head, on any ci engine it sits on. Drop the C5R intake on it and you'll make 50+ RWHP.
Old May 28, 2008 | 11:11 AM
AU N EGL's Avatar
You are correct. The C5R head is designed to use with the Kinsler Manifold.
Old May 28, 2008 | 01:51 PM
needadvice's Avatar
That Kinsler/C5R set up wouldn't be very good on the street would it?
Old May 29, 2008 | 06:31 AM
AU N EGL's Avatar
NO. plus it is bloody expesive.
Street use an LS7 would be better. The C5r block is a road racing block. Guys have used them for drag racing, not sure if that is a good idea as the cylinder sleeves are quite long and does not like high rpms.
the World LSx block would be a better choice and is also made from the same aluminum as the C5R blocks
Old May 29, 2008 | 06:13 PM
LSX-PWR's Avatar
I am using a BECK sheet metal intake on my C5R heads.
Old May 29, 2008 | 09:17 PM
1966goat's Avatar
I'd go with C5R heads
Old May 29, 2008 | 10:51 PM
needadvice's Avatar
over LS7's ?????????????
Old May 30, 2008 | 07:02 AM
AU N EGL's Avatar
Looking forward to seeing your results.
Good Luck on your project.
