update on my 402 build
Im forgeting all my automotive knowledge, me not working on cars since december.
I thought you were thinking about the caddys but then decided to stay with the ls7's?
Whats springs are you going to run? what lobes on the cam? There is a lot to matching it all up.
They come on the PRC 5.3 heads stg 2.5
Lemme try n list everything
Whatever TSP PRC 5.3 stg 2. heads come with thats what I have.
Although I was just checking my valves and Im very confused
the PRC heads have 2.02 int and 1.575 exh valves, he told me to make sure I dont have the 2.04, because it can either have 2.04 and 2.02. So I measured them..
I keep measuring mine and these are the measurments Im getting..
1.600" exh and 2.18" int...
2.18" is a Huuugeeee size, I dont get why Im getting this measurement.
could TSP actually accidentally installed this valve on their 5.3 heads??
I measured it 6 times, I got a lowest reading of 2.16 and I turned the valve and got 2.18... then every time 2.18. I even wiped off carbon to see if that was the difference...
no, 2.18" again.. wtf??
This is what I had before, stock 90k mile Ls1 with brand new Tv3 cam(now damaged) and 5.3 heads... this is the engine I had with caddy lifters
Now I have a 402, 238/244 cam, and reusing those 5.3 heads... This is the engine I wanna use my Ls7 lifters on because of bad experiences with caddy lifters
So the Caddy lifters are what I had in my old engine, LS1.. The caddy lifter collapsed which caused my engine to get damaged. WHich is NOW why im going with a 402 instead.. and Im NOW gonna use the LS7s, vs the Caddy lifters, which , like I mentioned I had in my old LS1....the only thing Im reusing from the old LS1, and thats being transferred to the 402 is my oil pan and 5.3 heads, Im replaceing a couple valves, the cam, maybe the rockers to the Harland sharps... I may use my pushrods, depending on if I need to. I have the 7.400"
my heads arent milled, but I am gonna run a slightly thinner gasket than before...
Comp XFI/XFI lobes
3017R/3038R HR113LSA +2 advance (111 installed intake centerline)
Cam Valve Events 0.006 0.050 0.200
Intake Duration - ID 288 238 159 3017R XFI lobe .615"
Exhaust Duration - ED 296 244 163 3038R XFI lobe .612"
Lobe Center Angle - LSA 113 113 113
Intake Centerline - ICL 111 111 111
Intake Valve opens - IVO 33 8 -31.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 75 50 10.5 ABDC
Exhaust Valve Opens - EVO 83 57 16.5 BBDC
Exhaust Valve Closes - EVC 33 7 -33.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 115 115 115
Overlap 66 15 -65 degrees
• Static/Dynamic Compression with new cam: 11.17:1, 8.20:1
• Recommended springs: Patriot Extreme dual valve springs with Ti retainers.
• Recommended pushrods: 7.425”
but Im afraid its 2.02 and 1.6
I hope that isnt a big enough dead for my cam to not work well.
BTW - How are measuring the valves? Post a pic using a dial caliper and valve with the LCD showing the measurements.
I know how to use the dial caliper, for some reason I read it wrong. I havent used one since dec 2007. I havent been doing anything automotive since then. Im losing my touch. :-/
Im replacing a few valves.. ALSo wtf is this crap I hear about the PRC dual springs breaking? why is everything defective?!
If you don't want to worry about breakage, don't start it.
