please help with me stroker motor
Old Jun 4, 2008 | 01:24 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You don't have to re-sleeve the block for 4.065" pistons...your machine shop will measure the piston diameter (which will be about 4.060"), and then they will bore/hone the cylinders to provide between .004" and .006" clearance between the piston and wall.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 4, 2008 | 01:33 PM
Stang's Bane's Avatar
Originally Posted by dkbykesdk
ok so im going to buy a 4.100 crank, 6.125 rods, an 4.065 pistons, that will make it a 426 right?
i dont have to hone block do i??
then that means it will need to be resleeved, honestly the motor is brand new
1) You need to call someone tell them what you want in the end, write them a check and sit back and wait.
OR
2) Start reading the stickies on here and they will answer every question you have had so far.
You need to choose one of the above. Because if you start ordering parts at random you are going to end up with a big pile of **** that doesn't work.
Old Jun 4, 2008 | 02:39 PM
dkbykesdk's Avatar
OR
lol ok.
Old Jun 4, 2008 | 03:01 PM
95FbFormula's Avatar
Originally Posted by Matt@Texas-Speed
Actually, the LS7 427 comes equipped with a 4" crank
4.065"x4.0" = 415
4.080"x4.0" = 418
4.10"x4.0" = 422
4.065"x4.1" = 426
4.080"x4.1" = 429
4.10"x4.1" = 433
lol i know I was debating putting that in but its not really interchangeable like the others do to the crank snout being longer
Old Jun 4, 2008 | 03:09 PM
dkbykesdk's Avatar
ok but ym question is, if i buy a 4.100 crank, an dont bore it, it will be a 426....... an just get some stock bore pistons (forged) an 6.125 rods
Old Jun 4, 2008 | 03:27 PM
lol ok.
What compression height are you going to order for your pistons??
Ring Pack??
Dish or dome??
Valve reliefs? Angle on them?? Size?? Placement??
That is just the piston questions. If you can answer all of those, then you have it figured out, if not, see my advice above. Good luck and I hope everything works out good for you.
Old Jun 4, 2008 | 03:48 PM
WKMCD's Avatar
Ring Pack??
Dish or dome??
Stop making sense...
Old Jun 4, 2008 | 03:53 PM
It is a fault of mine.
 Michael S. Palmer
