please help with me stroker motor
Old Jun 3, 2008 | 10:51 PM
dkbykesdk's Avatar
Default please help with me stroker motor
i got a 6.2l l92 short block.
what can i do to make it a nice stroker??
can i take a ls2 crank an put it in there an make it a 416?
will i just use the pistons from the 6.2l an rods???
please help me with this thank you
Old Jun 3, 2008 | 10:54 PM
95FbFormula's Avatar
you need a 4.000" stroke crank and bore the block .030 to get 416 stroker stock bore with 4.000 stroke is a 410-411
Old Jun 3, 2008 | 11:24 PM
dkbykesdk's Avatar
but i dont wanna bore it, so if i stick a ls2 crank in there you think it will be worth it, i can get the crank for cheap!!
Old Jun 4, 2008 | 07:44 AM
yes it would be fine just a stock 6.2
Old Jun 4, 2008 | 11:14 AM
dkbykesdk's Avatar
yes, do you think its worth it??? i will have a cam an stuff
Old Jun 4, 2008 | 11:37 AM
99blancoSS's Avatar
Just a little correction here...
The block is a 4.060, You clean it up .005 to make it a 4.070 and put a 4" stroke crank in it to make a 416. A stock crank is 3.62.
Sticking an ls2 crank in there does not make a "stroker"
Old Jun 4, 2008 | 11:52 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Quoted for truth!
They're 4.065" from the factory Also, the LS2 crank is the same 3.622" stroke as your LS1 crank, so throwing it in there will not yield any favorable results. Also, although not many people go .030" over on the L92 as of yet, we are doing some R&D on it and it looks promising! We have a L92 422ci short-block that we should have some firm numbers on (sonic testing and such) very soon!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 4, 2008 | 12:00 PM
99blancoSS's Avatar
Hey Matt what stroke is that?
Old Jun 4, 2008 | 12:04 PM
lol sry I was off on numbers a bit late night lol. But if you go with the stock crank it will be fine what are your goals their are L92/LS3 6.2 motors with Cam and bolt-ons making close to 500rwhp.
Old Jun 4, 2008 | 12:40 PM
dkbykesdk's Avatar
ok i want to make a stroker what do i do then? you guys confuse me one says yes an one says no
Old Jun 4, 2008 | 12:51 PM
99blancoSS's Avatar
TSP and I have stated it correctly. You need to use a 4" stroke crank to make a stroker.
Old Jun 4, 2008 | 12:54 PM
Then you need a 4.000" stroke crank here is a link to one.
http://www.texas-speed.com/shop/item...d=105&catid=37
That will give you the extra stroke you need to make a stroker motor
Old Jun 4, 2008 | 12:55 PM
dkbykesdk's Avatar
so if i just buy a 4" crank what will the cubic inche be if i dont bre it?
will it be worth it?
dkbykesdk's Avatar
dont ls2 have a 4" crank
Old Jun 4, 2008 | 01:01 PM
No LS motor comes with a 4" stroke crank the you can use also you have to at least hone the block like stated above and get pistons for the new stroke. so you need pistons for a 4.070" bore and a 4.000" stroke.
Old Jun 4, 2008 | 01:05 PM
99blancoSS's Avatar
If you dont hone it and stick with the 4.065 it would be a 415 at 4.060 its a 414
dkbykesdk's Avatar
well ****, what if i get a 4.100 stroker then what woould it be?
Old Jun 4, 2008 | 01:12 PM
Actually, the LS7 427 comes equipped with a 4" crank
4.065"x4.0" = 415
4.080"x4.0" = 418
4.10"x4.0" = 422
4.065"x4.1" = 426
4.080"x4.1" = 429
4.10"x4.1" = 433
__________________
99blancoSS's Avatar
4.060 with 4.10 stroke is 425
4.065 with 4.100 is 426
4.070 with 4.1 is 427
oops TSP and I typed at the same time lol, same info though
Old Jun 4, 2008 | 01:16 PM
dkbykesdk's Avatar
ok so im going to buy a 4.100 crank, 6.125 rods, an 4.065 pistons, that will make it a 426 right?
i dont have to hone block do i??
then that means it will need to be resleeved, honestly the motor is brand new
