Afr Ls7 Heads
The best business move would be a highport or canted valve head that would increase flow with minimal cross sectional increase and decrease in velocity.
Dont redesign the wheel copy what the ford guys have done and smile.
That bolt to factory manifolds.
We have c5r heads that do pretty well in racing situations.
It should never be a requirement that Race heads need to bolt onto factory manifold (that would kill the flow anyways). ET had/has the right idea but they can't seem to deliver on a consistent basis and are still coming up short in the flow department compared to SBC/SBF stuff unless you go to their canted valve head that is 2x more expensive than a better flowing SBF/SBC head.
We have Plenty of street/strip heads we dont need more.
I believe there is a strong advantage in the LS7 head over the LS1 head.
Of course you need a bottom end that needs that kind of head on top. Look how easy it if for damn near every cammed C6Z06 to make 540+ RWHP and then look at how hard it is to get a 408-427 with a catheral port to make 540+. There is a advantake to the LS7 port.
I highly doubt GM redesigned their head and intake completly if they felt a big runner catheral port would be the best fit for the new Z06.
6000.00 for the canted valve heads is not out of line for what complete race heads cost, take a set of all pro heads and add ti vavles, 600.00 vavle springs, ti locks etc. and you will come real close to that price.
The cathedral port was a cool experiment for a street car and makes great power. but even the c5r it cannot compete with other race heads for small block. that is what i am getting at there is no point to "better" gm's design it will make more power than 99% of the users eill ever need. Now someone has to do something for the other 1%. No reason a as-cast edelbrock $3000 for Victor Glidden or Kasse heads can go 400+ cfm out of the box and LS heads cant.
the canted calve is a great idea but unfortunately carries a huge weight penalty if it's even allowed in the class, and 6k is nothing for a good set of heads. My larry Meaux ported AFR's cost me close to 5k not incuding the valvetrain.
Yeah you right there is nothing special about it, but it has more potential then what has been found out of cathedral ported LSx heads.
I have done a dozen or so sets of ETP heads, and have used the 215's-245's. In comparison the ETP LS7 4" bore head easily out flows the 245's and especially once the manifold is bolted on.
I thought the main point of this thread was if AFR was coming out with a LS7 style head, and assumed the thread started was asking for something similar to what ETP has. Also assumed he was sticking with a stock intake manifold. So when I made my post I was also taking into consideration a manifold on top of the head, and figured a ported Fast 92 vs. a stock GM LS7 or ported LS7 manifold. This is where the LS7 style head can make a lot more power because it flows much better through the manifold.
