Honing Cylinders
Old Jul 9, 2008 | 05:53 PM
Nasty275SS's Avatar
Default Honing Cylinders
I need my cylinders honed to 3.905 to fit my pistons for the 383 i am building. The machine is very far behind and it would be awhile to get it honed and im real anxious. This is probably a dumb question but would it be stupid to hone them myself using the honer in a drill, has anyone ever done this on LSX's, if so let me know???!!!!
Old Jul 9, 2008 | 06:28 PM
fuseone's Avatar
you could but just to put it out there i wouldnt
Old Jul 9, 2008 | 06:41 PM
COMPRACER's Avatar
Racekrafters, lancaster, they do alot of LS stuff. check their web site
Old Jul 9, 2008 | 07:16 PM
kenSS's Avatar
i could do it for you. depending on how soon you need it.
Old Jul 9, 2008 | 07:43 PM
HTMtrSprt's Avatar
I would strongly recommend against using a hand hone. There is simply no way for you to get the cylinders as truly round as you need to assure good ring seal. These blocks are so flimsy that time spent on a good hone for proper size and finish is absolutely worth the effort.
Brian
HiTech Motorsport
Old Jul 9, 2008 | 09:46 PM
Nasty275SS's Avatar
I'd love for you to do the honing how soon could you have it done if i could drop it off some time this week???
Old Jul 9, 2008 | 09:57 PM
Nasty275SS's Avatar
OOOO Yeah, how much $$$$ does this machine work usually run???
Old Jul 10, 2008 | 11:22 AM
kenSS's Avatar
give me a call tonight and we'll talk. 717-333-5466. thanks kenny.
Old Jul 10, 2008 | 03:19 PM
LSZ's Avatar
LSZ
I would also reccomend not honing until you are ready for the shortblock to be put together. Surface rust occurs very easily!
Old Jul 10, 2008 | 03:24 PM
Nasty275SS's Avatar
KENSS i will contact you tommorrow (Fri.) because tom. im going to see a guy about doing the work locally (like 2 min. away). So i'll let you know either way!!!
Old Jul 10, 2008 | 07:45 PM
kenSS's Avatar
alright. i can meet you some where if you want me to do it for you. i have a deck plate for lsx motors
Old Jul 11, 2008 | 01:55 AM
BigBronco's Avatar
Please, do NOT hone the cylinders with a hand hone, even though you are just "bumping" over the cylinders.
As for the comment about the rust. It is "Flash" rust. Good prevention, which all machine shops do is this.
Take some automatic transmission fluid, pour it on a rag, and wipe all the cylinders down. It will prevent the rust from forming on the cylinder walls.
Old Jul 11, 2008 | 05:04 PM
TheLS1Kid's Avatar
Is a deck/torque plate needed for honing?
I know it would be better to simulate the head being on to make the cylinders as straight at possible, but if nobody has one locally would it hurt to do it without? I'd only be taking off 0.003"
Old Jul 11, 2008 | 05:26 PM
kenSS's Avatar
you might think you will be taking out .003" without the plate, but actually your really only taking about .003" at the bottom and about .002" up top. deck plate is def. recommended on any motor that needs a hone. i spend alot of time honing blocks. deck/torque plate is a must for accuracy.
