cam sprocket help
Old Jul 17, 2008 | 09:18 AM
greinder03's Avatar
Default cam sprocket help
what cam sprocket do i need to make a 3bolt cam work in a 2007 single bolt trailblazer ss ls2. please help, need to know asap
Old Jul 17, 2008 | 05:55 PM
fast377's Avatar
06 GTO I think.
Old Jul 17, 2008 | 07:32 PM
greinder03's Avatar
i used the cam sporcket i had for my ls2 in my f-body and it didnt work. will the 06 ls2 have the right one, even with the different reluctor wheel in the 06 motor. really need to figure this out my buddy's truck is a pain in the *** to start, especially with that ms4
Old Jul 17, 2008 | 07:38 PM
Blindmelon's Avatar
SDPC sell's a cam for your center bolt set-up. I have a 2006 & my cam came in from them with only the center hole so the machine shop drilled mine for the 3 bolt. Here is the number for it. SDPC also can get you the correct 3 bolt gear & chain set if you go that way.
Old Jul 17, 2008 | 08:48 PM
HSV-GTS-300's Avatar
3 bolt cam core / 4x cam gear
There were these kits on ebay, I think from LPE
Old Jul 17, 2008 | 09:04 PM
greinder03's Avatar
why do you have to run that different chain dapener, the sprockets are idential in diameter
Old Jul 17, 2008 | 09:19 PM
I don't fully understand why myself. There is something on this forum about it by one of the TBSS guys. Think they said there's a slight difference in the gear teeth on the recent gears. The post said that if you change to an earlier gear then change to the earlier dampener too.
There's an 05/06 black dampener thing and also a brown/fawn one from later years.
12588670 = LS2 Timing Chain Dampener (black one)
Old Jul 17, 2008 | 10:59 PM
Louis's Avatar
The 07+ LS motors for the most part (Save for Zs) use a single big bolt to hold the cam gear on the cam. This change was due to the cam phasers on the later model trucks/SUVs/etc, so they changed to one core.
The Cam gear to use is an 06 C6 ( Of any kind, LS2 or LS7) cam gear.
I made a post regarding this about the late summer of 06, it should be searchable in here.
