how bad is this?
how bad is it if i dont have it installed?
As far at 75lbs when the motor revs, that is good. You want at a minimum 10 psi for every 1K rpm you turn.
Not sure what you mean that you haven't tuned it yet? I hope you're not talking about tuning the oil pressure, cause....well....you can't haha, unless you swap out the spring in the oil pump for a weaker spring to bring down the pressures, but I wouldn't do that, as you're looking A'ok.
