LQ9 Questions... Cams heads and stuff
1.) What Cam would be better? Stock LQ9 or my GM Hot Cam and LS6 Springs?
2.) Would LS6 heads fit/work fine just bolted on like the way they are?
3.) What mods would need to be done or would it just drop into my car?
The reason I ask is because my motor is blown and well 6.0 wouldn't be a bad route. Please help ASAP before someone buys the motor... Thanks
PS. Probablly won't be spraying for a long while
2. yes
3. The only difference you "might" encounter from your ls1 to an lq9, depending on if it's an older block or a newer block is that the older blocks have one alternator bolt missing you'll have to drill and tap. Some say it's ok without it, but I'd drill it if it were my car.
Oh. Well yes.
They'll bolt on just fine, but your compression will be around 12:1 unless you either get a dish piston or an aftermarket head.
Im not exactly sure what your compression would be... I'm guessing 11.8 - 12.0
Chances are you'll need to run a higher octane gas or you're gonna get too much detonation. Gotta find out what the finished SCR would be. A thicker head gasket will help also.
