L92: Build #2
Old Sep 2, 2008 | 03:08 PM
2c5s's Avatar
Default L92: Build #2
2005 GTO A4 dd
LS7 block 427ci, WCCH ported L92's, ported L76, 22x/23x cc, factory TC, 11:1cr, 1 3/4 LT's, factory catback.
I'm going for a stealth daily driver the wife won't be embarrased driving when her goofy co-workers have to ride along.
Old Sep 2, 2008 | 03:18 PM
WKMCD's Avatar
Originally Posted by 2c5s
2005 GTO A4 dd
Should be interesting...Put a 4k stall in there and thrill the co-workers.
Old Sep 2, 2008 | 03:30 PM
2c5s's Avatar
I don't want them to soil their drawers on my real imitation leather GTO seats.
Old Sep 2, 2008 | 05:54 PM
99blancoSS's Avatar
If your going with the ls7 block then use the ls7 heads and intake. Other wise use the L92 block and save yourself the money. The LS7 block has the 4.125 bore and allows for the LS7 head.
Old Sep 2, 2008 | 06:08 PM
2c5s's Avatar
I've had the LS7 block sitting in the garage for the last 18 month's, it's getting built
Old Sep 2, 2008 | 06:27 PM
99blancoSS's Avatar
Ahhh, well then use the LS7 head/intake combo instead. Better results. You can still run a small cam and have it be docile and powerful.
Old Sep 2, 2008 | 06:44 PM
2c5s's Avatar
I'm running the LS7 topend in my C5, the L92 parts are from a previous build, they are ported and paid for and just collecting dust.
Old Sep 2, 2008 | 06:53 PM
firefighting1101's Avatar
sell the L92 stuff, and get the LS7 stuff. you will make much more power and probably not spend too much more. its definitely worth the time if you ask me.
Old Sep 2, 2008 | 07:27 PM
2c5s's Avatar
This is not a max effort build, it's a combination of leftover previously used parts from other projects. I know the LS7 heads/intake are better, but the small cam/stock TC does'nt justify the greater expense to aquire and build another LS7 topend. It's just another experiment to see what the L92's do with a very small sleeper cam.
Old Sep 2, 2008 | 08:55 PM
StreetnStrip's Avatar
Closed ex-Sponsor Account
Ur WCCH will be fine Rich does a really good job on cnc those heads. U wont be disappointed with his heads. I have a set of them going on our LS7 block that we are putting on our shop blazer. The cam Im running is a katech cam and I know it runs well in a LS7 motor with LS7 heads. Now Ill get the chance to see how the ported L92 heads will do.
Old Sep 2, 2008 | 09:18 PM
99blancoSS's Avatar
Well if you have them then you have them. I have a cam right now sounds perfect for what your looking for. Custom Comp cam 224/232 113 +2
Was speced for an L92 setup. New in the box. $370 plus shipping.
Old Sep 2, 2008 | 09:54 PM
2c5s's Avatar
What are the lobe numbers. Who spec'd it?
Old Sep 2, 2008 | 10:08 PM
99blancoSS's Avatar
3722R/3726R
Erik Koenig HKE spec'ed it. Was for an L92 smaller cubed engine than what your going with but its definately in your range. Maybe a little small for you but not really I woudnt think for what you want to do and your intake. Lift is .581 .595 My guess is it would be pretty good low and mid range power with a decent top end not going to break records but it was spec'ed for top end performance either. Just tossing it out there. Its a good cam for the L92's and smaller cubed engines but would be decent in your application as well. Maybe a little small for most peoples taste on here. But the application is the key to it. All useable power.
Old Sep 2, 2008 | 10:27 PM
2c5s's Avatar
3722R/3726R
Thanks, but that cam does'nt give me anything over the cam I've already spec'd.
Old Sep 2, 2008 | 11:02 PM
99blancoSS's Avatar
It's already ground and ready to go, thats all...lol I didnt say it was bigger or better just that it sounded similar to what you were looking for and I have it ready to ship.
Old Sep 2, 2008 | 11:11 PM
2c5s's Avatar
No problem, I'm just waiting on Wiseco.
Old Sep 3, 2008 | 09:34 AM
veee8's Avatar
That bigger bore with the LS7 block will really make those L92's shine. Sounds like a nice build.
Old Sep 3, 2008 | 07:14 PM
HTMtrSprt's Avatar
I know the LS7 heads/intake are better...
Actually, for your combination, the L76/LS3 intake is better. I dyno tested both the LS7 intake and the L76 manifold on a L92 head 454 and the L76 manifold makes significantly more torque down low because of it's longer runner. Since you are using a small cam and stock converter, I think you will find the L76 manifold performs VERY well in the real world. The LS7 manifold really shines above 5000 RPM and 600 fwhp.
Old Sep 3, 2008 | 08:05 PM
2c5s's Avatar
So you used a l76 intake on a ls7 head? How did you do that?
Old Sep 4, 2008 | 08:44 AM
HTMtrSprt's Avatar
No....but I used an LS7 manifold on an L92 head.....amazing things you can do with machine tools and a welder.
