Ls3 Ecu
Old Sep 4, 2008 | 05:03 PM
Pete walsh's Avatar
Default Ls3 Ecu
Hi and hello,
I have a ls3 that Im sticking in my rx7 and I dont know what kind of ecu came with the ecu i.e. E28/40/67 etc.
can somebody enlighten me.
cheers
Old Sep 4, 2008 | 05:19 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
it is a e38 ecu, there is no e28
Old Sep 4, 2008 | 05:37 PM
See5's Avatar
You can run it with most anything. Just need know the reluctor 24 or 58x ?
Old Sep 4, 2008 | 11:37 PM
Project GatTagO's Avatar
All LS3s are 58 tooth.
Andrew
Old Sep 5, 2008 | 01:45 AM
Pete walsh's Avatar
cheers so LS3's come with E38 ecu's as standard?
Old Sep 5, 2008 | 06:25 AM
See5's Avatar
If it is a stock GM LS3 it should have a 58x reluctor and the 08 LS3 Vettes have an E-38.
It is more common and easier to use an adapted E40 however. The PCM needs to have many IOs disabled and the harness simplified.
Old Sep 5, 2008 | 09:56 AM
71CamaroLS1's Avatar
As See5 suggests, you can make the LS3 work with earlier (97-04) ECUs by swapping the reluctor wheel and cam gear (24x reluctor wheel, 2005 LS2 cam gear).
If you don't swap the reluctor wheel, there is a version of the E38 controller that GM has released that is set up explicitly for retrofit swaps, complete with harness and DBW throttle pedal:
http://www.gmperformanceparts.com/Pa...roller_Kit.jsp
Just over $1K US, pretty inexpensive all things considered.
Old Sep 7, 2008 | 08:40 AM
LSX Wizard's Avatar
Actually, the GMPP kit is based on an E67 controller.
And it works very well.
Old Sep 7, 2008 | 04:42 PM
alocker's Avatar
An E38 or E67 will work with the 58x motor. It was my understanding that an E40 will only work the 24x motor.
The E38 is becoming pretty easy to find since they come in a ton of newer (07-up) GM cars. Your tuner should be able to get rid of all the excess junk pretty easily. Actually I will have one available shortly if your interested.
