is this ls2 block fixable?
Old Sep 4, 2008 | 09:09 PM
wlsmoku's Avatar
Default is this ls2 block fixable?
totally my luck.....came out of a trailblazer SS that drove it into water (pond) and hydro locked the motor breaking a rod.
#8 cyl....very bottom of sleeve. apx 1" width and depth
Old Sep 4, 2008 | 09:11 PM
DrkPhx's Avatar
It's trashed. You maybe could have it resleeved, but the cost is more than a new block.
Old Sep 5, 2008 | 03:02 PM
wlsmoku's Avatar
1 reply....i'm suprised! posted on a few other sites and they suggested a local machine shop that sleeves blocks. called him up and explained the damage and he said it shouldn't be a prob and since it's so low on the skirt, they may not even have to add aluminum back in, but will let me know for sure when he sees it. he said $75 labor and I pay for the cost of the sleeve.
Old Sep 5, 2008 | 03:45 PM
72VenturaII's Avatar
It's going to take a lot of machine work to exceed the price of a new block ($1200-$1300). I'd let the machine shop fix it.
Old Sep 5, 2008 | 03:57 PM
Grimes's Avatar
Time to pop for a new block. I would not trust a 75 dollar sleeve job.
Old Sep 5, 2008 | 06:07 PM
DrkPhx's Avatar
That's sounds to good to be true. Has that shop ever resleeved an aluminum LS block?
Check out Race Engine Development: http://www.raceenginedevelopment.com...4927/index.htm
They are a sponsor here and hold the patent to Darton sleeving process. Contact Steve and direct him to this thread for his expert and professional opinion. Also contact Jason at Katech and see what they recommend.
I had a block with less damage than that and opted for a new block for a piece of mind and more importantly reliability. Your call, but at least seek some expert opinions.
Old Sep 5, 2008 | 07:17 PM
fast377's Avatar
I'm sure it could be fixed, but you could probably score a used LS2 shortblock and have it machined for way cheaper. I did exactly what you did on an old 305. I just bored it, built it, and drove it. Left the chunk missing. Ran fine...then again, it wasn't any sort of race application.
FWIW I wouldn't re-use that block.
Old Sep 6, 2008 | 04:11 AM
myfast70's Avatar
Are you submitting the claim thru your insurance? If so, just buy a whole new short block from a sponsor!
Old Sep 6, 2008 | 08:46 AM
hookemdevils22's Avatar
I've seen similar damage on an iron block. A reputable engine guy was going to run it in his sand rail like that. One thing you should do, however, is check the adjacent cam lobe carefully. It was wiped in one spot in that engine.
Old Sep 6, 2008 | 12:19 PM
conkrete21's Avatar
If you're interested in a LS2 long block with after market heads and cam, let me know. I'm having a custom LSX455 being built right now and the motor should be coming out in 7-12 days. It has low mileage and made great power with the fast 90, ported tb and LT headers.
Old Sep 6, 2008 | 01:09 PM
KCS's Avatar
KCS
Moderator
It might be OK and it might not. Sleeved aluminum blocks seem to be hit or miss, but all that experience was with all 8 sleeves. I replaced sleeve may be OK. $75 wouldn't be that costly to find out, I guess.
Old Sep 7, 2008 | 04:40 PM
wlsmoku's Avatar
yes he has - infact he sleeves a lot of race engines I have come to find out. he's got 2 other ls2 blocks he's doing as well in front of me.
pulled everything apart today, and theres a slight score in one of the other cyl, but I am pretty sure it will come out pretty easily.
he's a very reputable builder around these parts, so I'm feeling more confident this will be ok. i'll let you all know what he says though.
Old Sep 12, 2008 | 12:36 AM
lteone's Avatar
hurry up because he is doing ours at the same time.
Old Oct 13, 2008 | 03:59 PM
So was this block fixable?
Old Oct 13, 2008 | 05:11 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Fixable? Probably. Its hard to tell from the pictures, but the cost of resleeving is going to exceed the cost of a new LS2 block.
Old Oct 14, 2008 | 12:25 AM
Sorry - wrong verbage. Useable? I had an iron block that had the same stuff (see above), but there was a weld repair at the main oil galley (= no bueno). The chipping at the bottom of the cylinders is not a *MAJOR* concern (and I stress MAJOR) - it's a fairly low-stress area. That being said, that is some healthy damage to the cylinder.
And who would ever pay to have a block resleeved anyway? Unless it was a rare piece, that's simply asinine.
