is this possible
Old Sep 5, 2008 | 05:23 PM
krusemj's Avatar
Default is this possible
I am in the process of ordering forged pistons and rods for the ta. I was just wondering if you could replace them with out pulling the motor. Once I did that to a buick when I worked as a mechanic but dont know if you could with an fbody. Just dont have alot of equipment or room now that I am in the army.
Old Sep 5, 2008 | 07:29 PM
moeZ28's Avatar
Its so easy to pull the motor in these cars, it would just be too big a pain in the *** not to pull it to do the work.
Old Sep 5, 2008 | 07:42 PM
camarols1's Avatar
You are much better off pulling the engine.
Trying to install the pistons/rods into a block that is still bolted to the car will be a PITA.
Not to mention the chance of getting dirt in the engine while climbing all over it.
The crank will need to be balanced anyway, so just pull the engine and be done with it.
Old Sep 5, 2008 | 08:09 PM
krusemj's Avatar
Do you know where there is a good engine removale how to
Old Sep 5, 2008 | 08:20 PM
TA-Swede's Avatar
I have yet to do this, but from what I've gathered it's pretty easy actually.
The steps that I know of (I'm sure people will fill in what I'm missing):
* Unbolt the top of the strut towers from the inside of the engine compartment
* Remove the ECM, and unplug the harness that goes into the passenger compartment (the connector is on the inside of the car)
* Negative and positive battery cables that goes to the starter and alternator
* Brake booster hose
* Put a support under the tranny to keep it from falling backwards
* Unbolt the (six?) bolts holding the subframe and K-member to the chassis
* Lift the chassis (slowly to see if you've missed anything) off of the engine/tranny/front suspension.
If I recall correctly, the TV show Musclecar did a walkthrough of this on their 4th gen Camaro. Couldn't find the clip on their website though.
Old Sep 6, 2008 | 01:28 PM
moeZ28's Avatar
You can pull the motor out the top as well...just as easy as anything else. I have seen it and done it this way several times!
