did I over cam?
Old Sep 9, 2008 | 05:40 PM
VGLNTE1's Avatar
Default did I over cam?
running a 416 LS3 with ported L92 heads 65cc with L76 intake.
cam currently is a 232/246 115+4.
For having stock heads and a crappy intake, its kinda ruff around town. Also been tuned 2 times. All I have seen are small cam with these heads...should I drop it down?
on a mustang dyno and 4.10 gear in a C5 it made 465/440
Old Sep 9, 2008 | 06:02 PM
JPH's Avatar
JPH
Your not that far off IMO. What lift?
Old Sep 9, 2008 | 06:15 PM
White_Hawk's Avatar
I have almost the exact same cam and have it running great with an A4 on a 403. The idle was a bitch to get dialed though. Still bucks a little when the convertor locks up, but I am locking it up pretty low (around 40). I am sure I could get it better if I spent more time on it too.
-Geoff
Old Sep 9, 2008 | 06:38 PM
sciff5's Avatar
It sounds like for the manners you want around town it might be too much cam. Should try a speed density tune. With a SD tune a good tuner can improve its manners around town.
But as for making power your still WAY far off from having too much cam.
I am looking at a 245/250 cam for my 346
Old Sep 9, 2008 | 07:55 PM
WKMCD's Avatar
FWIW: Much smaller cam, much tighter lsa in a 403 w/ 3/90's w/ a Z06 Ti's and cats. There's more with the cutouts open but this is all you get.. I can lug it down to 600 RPM in 6th and pull away cleanly. It truly drives as close to stock as you'll find.
Old Sep 9, 2008 | 08:00 PM
VGLNTE1's Avatar
yes, we have talked before. I think you run the G5X3 cam right?
Old Sep 9, 2008 | 08:01 PM
VGLNTE1's Avatar
does your 346 have L92 heads?
VGLNTE1's Avatar
-Geoff
idle is actually good. and around town its not so bad. it just dosnt seem to run smooth on the highway unless im above 1700 rpm
Old Sep 9, 2008 | 08:25 PM
sciff5's Avatar
I havent run the cam yet I actually got the idea from DemonicBird00
Hes running that cam with stock heads and DIDNT need to flycutt the pistons thats what attracted me to that setup.
Old Sep 9, 2008 | 08:55 PM
WKMCD's Avatar
My last cam was a 234-240 112 +- XE-R..Smaller than a G5X3. My current cam is smaller than my last cam in some regards but has MUCH more lift. Still on a tight LSA. I made 510-470 with the last cam. This one just makes more everywhere after 4k RPM.
Old Sep 9, 2008 | 08:59 PM
VGLNTE1's Avatar
does a cam in this set up really make a ton more power though? or is it like 10 to 15? Its not like the cam makes whole deal come to life does it? from your worst cam to yoru best, what is the hp/tq difference?
Old Sep 9, 2008 | 09:00 PM
VGLNTE1's Avatar
well with a 416...if I had cathederal heads, id be in the 25x/26x range. the L92 heads are jsut a different breed...plus the shitty intake dosnt help either
Old Sep 9, 2008 | 10:28 PM
White_Hawk's Avatar
Is that the only problem? What exactly is it doing? A4 or M6? With 4.10's on the highway You are talking like 45 mph or so aren't you?
-Geoff
Old Sep 9, 2008 | 11:12 PM
VGLNTE1's Avatar
-Geoff
MN6. its just kinda ruff. if i floored it in 6th gear at 1300 RPM, it would bog and choke kinda. Its doable...I was jsut cuious if my cam was to much
i think the RPM at 75 with 4.10's in my C5 is like 1800
Old Sep 10, 2008 | 05:40 AM
WKMCD's Avatar
My first cam had 19 degrees of overlap and made 480+ RWHP but was pretty much untunable for my purposes. The second cam had 13 degrees and my current one has 11. We also lowered the compression between the first and second cam from 12:1 to 11.4:1 and added a bunch of spark lead.
Total diff from 1st to 3rd cam is over 35RWHP but drivability and mid-range RWHP and RWT is up considerably. These builds are very cam-centric. I can roast the tires with a small romp from 1k RPM and up and smoothly cruise through the neighborhood in 3rd at 1400RPM (27MPH). Tip is is incredible.
Old Sep 10, 2008 | 11:42 AM
White_Hawk's Avatar
If that is the only time you have an issue, then I wouldn't sweat it. Just downshift. Small price to pay for the performance.
Nice thing about an A4 is that I never see full throttle at that RPM for more than a spit second.
-Geoff
Old Sep 16, 2008 | 04:53 PM
Greg Fell's Avatar
whats wrong with you man!
Old Sep 16, 2008 | 05:27 PM
AU N EGL's Avatar
1300 rpms is 2nd gear, or even 1s1.
6th gear is not a performance gear but a highway crewzing gear
Old Sep 16, 2008 | 06:26 PM
edcmat-l1's Avatar
Something's way off in that thing. You're missing a big chunk of power. Are the guys that are tuning it, familiar with tuning the L92s? The dont just like a dif cam, they like a dif tune. I've made huge gains in retuning L92 combos for people that have had them tuned elsewhere. The driveability should be good with that cam too. I've tuned some crazy **** and had em come out real nice and drivable.
If they tuned it like a ls1 cathedral motor, I probably know where a good 25-30 hp is.
Also, who built it, and who ported the heads? You can screw up a set of L92s if you're not familiar with them.
Can you post a graph?
It could have a **** valve job. It could have the springs setup wrong. I could go on, but you get the idea.
Plus its on a Mustang, so depending on how its configured, that could be costing you some numbers.
