ls3
Old Sep 14, 2008 | 04:06 AM
massillongoat's Avatar
Default ls3
pro and cons of the ls3....I have a buddy thinking of purchasing and ls3....
ls3 swap in an ls1 camaro in the future
Old Sep 14, 2008 | 09:43 AM
Robin L's Avatar
LS1Tech Sponsor
Haha, cons.....there are no cons.
Hmmm, with a cam you can make close to 500 horsepower. Oh yeah the top cam gear will need to be changed to a 3 bolt from the single bolt that they use now.
You will not be able to run a 1x gear in an LS3 because of the single bolt. What a great excuse to install a cam while your changing the cam gear.
You will need the typical harnesses for the cam pickup, injectors and knock sensor. Do a search there is a good post abou the changes that you will need to perform.
Robin
Old Sep 14, 2008 | 10:11 AM
shady milkman's Avatar
Robin
wow ..you hit everything on the mark...i have nothing to add..
Old Sep 14, 2008 | 10:23 AM
99blancoSS's Avatar
I agree with Robin, no cons at all. Bigger is always better
Old Sep 14, 2008 | 10:52 AM
See5's Avatar
24x reluctor
Old Sep 15, 2008 | 07:21 AM
drain89's Avatar
Instead of paying an arm and a leg for an ls3 crate motor, I'll sell you my zero mile L92 crate motor and swap parts for one hell of a deal.
Old Sep 15, 2008 | 07:54 AM
njc.corp's Avatar
Smile
Robin
robin- just cam alone and the usual springs etc etc?
Thanks
Nick--
Old Sep 15, 2008 | 08:18 AM
Robin L's Avatar
LS1Tech Sponsor
Thanks
Nick--
The GMPP LS376/480 is an LS3 with a GM Performance Parts Hot Cam installed.
The engine is part number 19171224
This engine makes 480 Horsepower. The LS3 has the LS6/LS2 yellow valve springs already from the factory.
As you know this cam isn't that radical.
I am getting ready for some testing on the dyno soon.
I will running the following,
L92 with a Lunati Voodoo 232/238 Cam and L76 Intake
LS3 With a Lunati Voodoo 212/218 Cam and a 4 Barrel Intake and Distributor
LS2 With a Lunati Voodoo 224/228 Cam, LS3 Heads and LS3 Intake
I will try the Hooker F Body 1 3/4 and 1 7/8 headers o each combination.
If I see anything interesting I will swap some of the cams around. If I see the potential I have a set of GMPP CNC L92 Heads to try also.
The L92 and LS3 are 58 tooth reluctors. I will run a MSD converter on the Carb engine and the GMPP Computer and harness on the L92.
The LS2 is a 24 tooth reluctor so I will run an 99 F Body PCM tuned with HP Tuners.
We will also be running the new Abaco Digital Mass Air Meters on both EFI Engines
Should be fun!
Robin
Old Sep 15, 2008 | 08:27 AM
njc.corp's Avatar
Thanks for the quick reply and facts
I would be happy to hear some more results in due time
Thanks
Nick--
Old Sep 18, 2008 | 01:24 AM
Bring the Noise's Avatar
Should be fun!
Robin
I wonder what that LS2 and Voodoo 222/228 (60511) will do with a LS3 top end
