Piston change
Old Sep 21, 2008 | 11:54 AM
ddcarter's Avatar
Default Piston change
If I change out my pistons but keep the weight the exact same will this affect the balance of the rotating assembly?
Old Sep 21, 2008 | 12:49 PM
racer7088's Avatar
No but you also have to make sure that the pistons and piston pins and rings all end up as a group coming out the same or a little lighter and then you could get by without rebalancing.
Some pistons are lighter but the pins and rings may be different too so look at it all as a package bfore you assume the pins and rings are the same but if they are you would be good to go.
Old Sep 21, 2008 | 01:57 PM
ddcarter's Avatar
I have reversed dome pistons now and want to swap for flat tops. I am hoping to use the same rings and possibly pins. I bought a rotating assembly and changed directionon project.
