Oil Pan and Valve covers
here is his link: http://www.billetfab.com/index1.htm
I like the idea of the 2 piece pan myself.
It looks like a neat set up to me.
What do most people use for their stuff?
I'm building an LS7 and he makes both pan and valve covers. I'm sure if you call he more than likely makes them for the LS1.
I just like the idea of a 2 piece pan. That way you can check your rods & crank bearings without dropping the whole pan.
I went to check them out and did see any.
Not sure what you're building or how pan is pieced together but most cars require that you drop the crossmember to get the oil pan off.
I'm not sure on how your crossmembers are connected. Are they welded in or bolted? I think if I had one I would make it a bolt in for service reasons.
Just my .02¢
Most trucks and older cars have welded cross-members making it necessary to loosen motor mounts and jack up motor to remove oil pan.
