what heads for my 416ci setup???
416ci L92 Aluminum Block 4.067 Bore
Eagle 4340 Forged 4" Crank
Scat 6.125" Forged H-beam Rods W/ ARP Bolts
Manley Forged 2618 -2cc Pistons
242/242 .595/.595 Lift Cam 112 LSA
Edelbrock Victor Jr EFI Intake Manifold
Kooks 2" Headers
TFS heads work with yella terra LS1 rocker arms.
Look for a used set of AFR's or TFS, hard to find they go quick when. Stage 3 LS6 head isn't the least expensive cnc'ed oem head either. Cartek as well as a few others in addition to who's already been mentioned should be considered. Look at race results to see who's heads are making power.
Some stage 3's outshine other stage 3's so you need to do some research on them. Where an AFR or TFS or ET head is a proven aftermarket performer out of the box. I can swing you a deal on AFR's, I'm having a sale on them but they aren't going to be as cheap as a ls6 head still.
Issue with used heads, you don't know what your getting into. Anytime someone brings us a set of Used heads. We have them cleaned, milled, replace valve seals and check valve job, before the heads are installed, your anther $500 into them, assuming they don't need any valves, guides or springs.
https://ls1tech.com/forums/showthrea...highlight=wcch
