Fbody accessories will fit the ls2 and ls3 ?
Old Sep 25, 2008 | 02:53 AM
jfman's Avatar
Default Fbody accessories will fit the ls2 and ls3 ?
Will fbody accessories (power steering pump, water pump and alternator) fit an ls2 or ls3 motor ?
Also will the coil packs from an ls1 work with the ls2 harness.
Crankshaft pulley ?
Basicaly can you run the the ls1 f body accessories on a gen IV motor using a gen IV harness ?
Old Sep 25, 2008 | 02:37 PM
UKRob's Avatar
Well I am going to find out soon...
From what I understand the blocks have common mounting for the accessories so they will mount up, but whether your harness will have all the right connectors is something that will depend on what you re using.
Old Sep 25, 2008 | 03:10 PM
Steve1969LS1's Avatar
Yes,
I'm running full F-body accesories on my LS2 engine.
