BADDEST 408 short/longblock?
Let me know what your goals are and I can draw up a detailed quote for you to look at. We build them from mild to wild for customers on this forum every day!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
We use Callies crank and rods and Wiseco pistons, ACL race main and coated rod bearings, ARP. I'll pm you with some information.
My engines were designed and are built for hi hp applications with boost and n2o.
You are going to do great with most any of the LS1tech sponsors here like TSP or LME and many others. I am here working at 1am like usual and I just can't answer all the calls I get anymore. I do engines for many of the vendors here as well. 99blancoSS has his engines done by us and could help you too.
TSP especially above also has some great deals too with very fast turnaround or even in stock already so if they have something right for you you can get it much quicker. Unfortunately with the backlog of work we have we are always catching up and the hurricane didn't help anything either!
You need to decide what you really want out of your engine and look at your budget and go from there. Also make sure when you are shopping you compare apples to apples as many shops have different options you can add or subract depending on what you need or want. If you want a quote from us you could go through 99blancoSS as you might never reach me on the phone unless it's 3am!
