Project Re-ring 416
Old Mar 17, 2026 | 01:20 PM
1FastBrick's Avatar
I should also Preface that I do this on the side for fun.
I don't build on the level Scott does in terms of volume of motors built. But me experience with both brands has been the same. I always end up needing to purchase 2 sets to get the clearance right.
Old Mar 17, 2026 | 07:26 PM
I keep a drawer full of multiple sets of mains…up and down, and rods…up and down. On average I’ll go through 2 boxes of each to get my numbers. I did a build last summer that I found my mains numbers in one box, and I was floored. I opened 3 boxes to get the rods right, but that’s normal with China rods. Fwiw, I find much more consistency with Molnar cranks and rods. For every build I bring in, I simply order another set of std mains and std rods, and mix them in the drawer to replenish my stock. I’d imagine there’s $2500 in bearings in that drawer.
Old Mar 17, 2026 | 08:03 PM
1FastBrick's Avatar
essentially I do the same. Tool box drawer full.
Old Mar 22, 2026 | 01:36 PM
65LSXNOVA's Avatar
Well the TFS 235 heads sold. When I CCed the intake port runners they where 229cc on them. I've made up my mind and im ordering the new BTR canted cathedral port heads. Those have 250cc intake runner and im hoping the intake port openings are wider than the old TFS 235 so my holley split intake port alignment to head port is better.
Since this is a carb setup with a 1050 cfm 4150 on top i didn't want to totally kill drivability and lose carb signal with a large rec port single plane and rec port heads.
Im also changing the rear gear from 3.42s to 4.10s to help with drivability since im going with a larger port head and a larger cam.
Old Mar 22, 2026 | 02:56 PM
DualQuadDave's Avatar
You can't go by the port cc to really determine anything. The CSA and airspeed of the port will determine the carb signal. I doubt the intake will be wider than TFS heads, but you might call them and get a dimension.
Old Mar 22, 2026 | 03:49 PM
65LSXNOVA's Avatar
Most of time when you have a wider CSA low speed port volecity suffers which inturn effects carb signal at part throttle. Another reason why im switching to 4.10s. In overdrive ill be cruising 400 rpm higher at 70mph to help, IF these larger heads and cam turd out part throttle cruise like i expect them too.
Old Mar 22, 2026 | 04:32 PM
I wouldn't sweat it, I don't think the CSA is going to be radically different. You are going from a 2.08 int valve to a 2.125, I'm sure the CSA is more, but nothing like a LS3 head size. I think it'll run good, love to see the heads when you get them. Who is porting them?
Old Mar 22, 2026 | 04:47 PM
65LSXNOVA's Avatar
calling GPI in the mornin, hope to have good news tomorrow. Brian Tooley said ill have to flycut the pistons most likely with the canting of the valves. Plus im sure the pushrods will be quite different.
Old Mar 22, 2026 | 07:16 PM
You will absolutely have to cut the pistons for the valve angle (canting), if your previous setup was even remotely close. I feel like a lot of people are going to try and throw these heads on a flattop bottom end, and run into valve clearance trouble. The canting puts the valve a lot closer to the piston.
Old Apr 17, 2026 | 11:59 AM
65LSXNOVA's Avatar
Finally got the heads delivered. Just mocking them up with 1 head bolt installed and intake manifold just sitting on top, the new heads port alignment is way better than the old tfs 235s.
The port width at the entrance on the old 235s where 1.069 wide vs the btr heads have a 1.1150.
New btr head along with holley split single plane
Holley single plane with tfs 235 heads
Old Apr 17, 2026 | 11:12 PM
Bob570's Avatar
She's a beaut. Can't wait to see how it does! Any plans to put it on the dyno?
Old Apr 18, 2026 | 06:59 AM
Double06's Avatar
This should be very interesting. Heads look great did the flow them at all?
Old Apr 18, 2026 | 07:24 AM
65LSXNOVA's Avatar
im not sure as I didn't get a flow sheet.
Old Apr 18, 2026 | 07:25 AM
65LSXNOVA's Avatar
no plans for engine dyno, maybe a chassis dyno.
Old May 4, 2026 | 08:15 PM
65LSXNOVA's Avatar
Received my manton pushrods today. Installed some light weight checker springs on the intake and exhaust valves. Placed some playdoh on top of the pistons to check PTV. Rotated the engine over two complete times and the pistons didn't come close to the valves. I think that seams very strange. The cam is a BTR 246/260 111 lsa but that with using 1.8 ratio rocker arms. Im using 1.7 ratio. I confirmed the cam is installed dot to dot like the cam card calls for.
Old May 4, 2026 | 09:36 PM
Well…I stand corrected. Is that a large chamber casting you have there? Was it cut any? Valve drop is setup high obviously by Brian to compensate for the cant, to help with PTV. That’s good news. Appreciate the post.
Old May 5, 2026 | 05:30 AM
65LSXNOVA's Avatar
I think its the standard 61cc chamber. Ill measure this week some time. Maybe thats why the pushrod length is over .600 longer than LS pushrods. I know the LT valves are around .300 longer than LS valves.
Im going to put a dial indicator on the valve retainers and measure clearance soon just to ne sure.
Old May 5, 2026 | 07:25 AM
Woodylyf767's Avatar
Play do force stronger than un pumped lifter springs and checker springs?
Old May 5, 2026 | 07:31 AM
  #39
Double06's Avatar
Post a photo of the chambers if you have now put heads on.
Old May 7, 2026 | 08:36 PM
  #40
65LSXNOVA's Avatar
