l83 turbo build questions
Here is the current budget plan-
AFR gauge - 150
Boost gauge - 80
exhaust manifolds and tubing - 100 (custom fabbed from junk headers)
denmah turbo kit from vsracing - 868
tune + dyno - 500
total - 1698
This budget however does not include fueling, mainly because I have no idea what a direct port engine needs fueling wise. I heard that the stock injectors are pretty much maxed when running e85, so im thinking they could handle 500 wheel on 93 but not on e85. Would it be worthwhile to upgrade the fuel system to run e85 for anti knock purposes or would 93 octane be enough to prevent knock?
Put all the money you can into making or buying the best turbo kit you can, then save for a cam swap.
